Plug ins not seen on instrument drop down
Hi.
I'm new here, so first "hello" and second, sorry if this is a thick question / post. I've recently bought ProTools and am running it on a Mac Pro. I have bought NI Scarbass Pre Bass and have downloaded in (3.1GB) it is sitting in the downloads on my Mac. Problem....I can't see it on my instruments dropdown when I set up an instruments track. ≈ All the ProTools package instruments are visible. This is my first plug in purchase. Any thoughts please? Peter |
Re: Plug ins not seen on instrument drop down
Hi Peter. Do you have NI Kontakt installed. You will need this to use it. I think you'll find that the pre bass is an instrument library (samples) which you need to load into Kontakt.
Being you are new to all this I'd like to pass along a few things you may or may not know: PT wants to have a separate hard drive from your system drive to record to and not a partition on an that drive. Also if you are going to be using a lot of sample-based vi's you might want to think about a separate drive for them as well. No green drives and a minimum speed for a spinner of 7200 rpm. And have all energy saving features inside OSX disabled. |
@musicman691 - any tests or anecdotes for improvement seen with third drive ?
Sent from my iPhone using Tapatalk |
Remember with everything on one drive, especially if you're running a spinner, is everything is coming off one read/write head assembly, not to mention one data pipe. The read write assembly can only move so fast. |
Ok thx!
Hi People.
Thanks so much for the help. No I had not downloaded the driver for Kontack. That fixed it. When I used CuBase, I'm sure all of the instruments loaded directly. You have been so helpful. I'll also look at the second / third drives. Cheers. Peter Brookes |
AAX Instrument Plug-Ins dropping from Instrument Track | stardancer | AAX Plug-ins | 2 | 09-12-2015 08:26 PM |
Instrument track inactive after removing plug in OTHER than instrument | pshammond | Pro Tools 12 | 13 | 07-25-2015 09:19 AM |
Plug-in volume drop problem | amac84 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-08-2009 03:52 AM |
Peculiar Instrument Track MIDI drop-out | jeff markham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-24-2009 09:01 PM |
help i can't find sampletank on plug in drop down | samrisio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-06-2004 01:39 PM |
