Plugins in for pro tools 1?
I am trying out pro tools 1, and It will not allow me to use the izotope nectar plug-in? are you only allowed to use pro tools plugins, in pro tools 1?
Re: Plugins in for pro tools 1?
You can use plugins you have a license for.
Pro Tools 1 came out in 1991. Not sure if it supported plugins.
What do you mean by it won't let you use it? Is it not showing up in the plugin menu or is it giving you an authorization warning? |
http://avid.force.com/pkb/articles/e...s-First-FAQ#16
Q) Can I use any AAX plug-ins with Pro Tools | First? A) Over 20 plug-ins are included with Pro Tools | First including the Xpand!2 Virtual Instrument. Pro Tools | First supports AAX Native 64 and AAX AudioSuite 64 plug-ins purchased from within the in-app Store. Check the description/specs in the Avid Marketplace to confirm if an iLok is required. Plug-in bundles which include ‘First’ in the name are specifically designed for use with Pro Tools | First and do not require an iLok. These plug-ins should download and automatically install, without needing to re-launch Pro Tools. Only plug-ins purchased through the Avid Marketplace with your Avid Master Account will work with Pro Tools | First. All other plug-ins will remain hidden and unavailable at launch. If you purchase plug-ins for Pro Tools | First then upgrade to Pro Tools, those plug-ins will be available as the AAX Native 64 format is exactly the same for Pro Tools | First and Pro Tools. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
http://duc.avid.com/showthread.php?t=371704 |
isn't Nectar only 32bit?
It depends on the exact version he is talking about. The latest version is AAX64 bit.
But, I believe by Pro Tools 1 the OP means Pro Tools | First, so in that case he won't be able to use any plugins he may already have. Only plugins purchased from the Marketplace will work in PT|First
Pro Tools 11.3.1 - No Plugins | snape | Pro Tools 11 | 1 | 03-26-2015 09:45 AM |
Updated to Pro-Tools 10.3.6 Now Pro-Tools won't load plugins and audio suite plugins | nyspaz | macOS | 1 | 07-27-2013 02:16 PM |
Pro Tools Plugins Plugins Plugins | psmworld | Buy & Sell | 0 | 01-31-2013 10:33 AM |
Pro Tools 9 & AIR Plugins | New Dimension Studios | macOS | 9 | 06-30-2011 12:18 AM |
Plugins for Pro Tools LE vs Pro Tools HD question? | zilby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-31-2005 08:05 AM |
