i cant get my micro korg to work with PT midi
i would really like to use my microkorg to play xpand2 and do other things as a midi controller. i have been searching for a week for an ansewer and im freaking out!
Re: i cant get my micro korg to work with PT midi
Using Korg R3 as MIDI controller without any issues in PT 8.0.3 on Mac.
Did you see incoming MIDI messages?
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8 mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop r3, microQ, Albino3, impOSCar, Structure m1active 520 & sub gw s750, deq230, cx2310 |
how did you set it up??? when i go to midi studio setup the microkorg snt on the list?
also wenever i get to input or output port it says "none" no other options. :@
should the midi ports show up in the i/o setup?????? this is so frustrating i bought the better interface with midi ports and its like they r not there
The are 3 possible modes of how Korg R3 can route MIDI messages (probably micro Korg designed this way too):
thank you, im checking this out now.
BTW: Look on your System Profiler. It should show all connected USB devices. Than it guarantee that they will be visible in "Audio MIDI Setup".
http://farm3.static.flickr.com/2751/...fd6e35f4_o.jpg http://farm5.static.flickr.com/4009/...6235ef3f_b.jpg
im using vista basic....
Acer Aspire T180-US340B Desktop Specifications
Part # AST180-US340B Manufacturer Acer Manufacturer Part # AST180-US340B Type Personal computer Product Form Factor Mini tower Processor Type AMD Athlon 64 X2 3400+ 1.8 GHz Multi-Core Technology Dual-Core 64-bit Computing Yes Installed Qty 1 Max Supported Qty 1 Cache Memory Type L2 cache Installed Size 256 KB Mainboard Chipset Type nVIDIA nForce 430 RAM Installed Size 512 MB (512 MB x 1) / 4 GB (max) Technology DDR II SDRAM Memory Speed 533 MHz Memory Specification Compliance PC2-4200 Form Factor DIMM 240-pin Storage Controller Type 1 x Serial ATA - integrated Controller Interface Type Serial ATA-150 Storage Hard Drive 160GB Serial ATA Optical Storage Type DVD±RW (± DL) Card Reader Type 9 in 1 card reader Supported Flash Memory Cards CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, SmartMedia Card, xD-Picture Card Monitor Monitor Type None Graphics Controller Type Integrated Graphics Processor / Vendor NVIDIA GeForce 6100 Audio Output Type Sound card - integrated Sound Output Mode 7.1 channel surround Compliant Standards High Definition Audio Input Device Type Mouse, keyboard Telecom Modem Fax / modem Protocols & Specifications ITU V.92 Networking Networking Network adapter - integrated Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet Expansion / Connectivity Expansion Bays Total (Free) 2 ( 1 ) x front accessible - 5.25" x 1/2H 2 ( 2 ) x front accessible - 3.5" x 1/3H 4 ( 1 ) x internal - 3.5" x 1/3H Expansion Slots Total (Free) 1 ( 0 ) x processor 4 ( 2 ) x memory - DIMM 240-pin 2 ( 2 ) x PCI 1 ( 1 ) x PCI Express x1 1 ( 1 ) x PCI Express x16 Interfaces 6 x Hi-Speed USB - 4 pin USB Type A ( 2 in front ) 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) 1 x serial - RS-232 - 9 pin D-Sub (DB-9) 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) 1 x IEEE 1394 (FireWire) - 6 pin FireWire 1 x microphone - input - mini-phone 3.5 mm ( 1 in front ) 1 x headphones - output - mini-phone stereo 3.5 mm ( 1 in front ) 6 x audio Power Device Type Power supply Voltage Required AC 120/230 V ( 50/60 Hz ) Power Provided 250 Watt Operating System Microsoft Windows Vista Home Basic Software Included Acer Empowering Technology (eRecovery Management, ePerformance Management, eDataSecurity Management) Adobe Acrobat Reader CyberLink PowerDVD Norton AntiVirus NTI CD-Maker Gold Ambient Temperature Min Operating Temperature 50 °F Max Operating Temperature 95 °F Humidity Range Operating 10 - 90% Dimensions (W x D x H) Unit 7.2" x 17.9" x 14.6" i upgraded to 2 gb ram and a raedeon x800 graphics card hope this helps, is my computer [bleep][bleep][bleep][bleep]y?? is that the problem?? |
Question on multi-timbrality in PT of Korg micro-synths | sproyd | MIDI | 1 | 01-14-2011 12:47 PM |
Any way to work with 96K LE Projects using the Micro? | mjake03 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-02-2009 09:16 AM |
getting Korg padKontrol to work with ProTools LE | spowers6 | Pro Tools M-Powered (Win) | 3 | 01-08-2008 05:32 PM |
Will a Korg Micro Kontrol work for PT 6.4? | petedaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-01-2006 11:50 PM |
how to make korg legacy work? | majakic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-28-2004 07:46 PM |
