#91
Re: 44.1 kHz vs. 48 kHz - why not use the higher?
#92
I would never convert sample rate at the same time as mixing. My preference is to always buss mixes to a new stereo track so I can go back and punch in any problems or compare and comp between different mix versions.
If you are using PT 10, I would change the session setup to record that track in 32 float unless I had a plug-in that offers 24 bit dither. Then you can do a file export to any format you need including 44.1 x 16 which Pro Tools will dither properly. Earlier versions that can't do 32 float sound better to me with some kind of 24 bit dither such as PSP Xenon, Oxford dynamics, Ozone, or one of the waves L series.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#93
I'm aware of the Nyquist–Shannon sampling theorem. But if I understand correctly there is more to it than just the sample rate that affects a signal being recorded ? Another thing I have noticed is that there is a difference between hearing vocals, guitars, bass, drums, etc live and hearing a playback of the same thing. Something is lost one the way in or on the way out of a recording/playback system. Or maby i just don't have a good enough system |
#94
From a simple recording/playback aspect many experts consider the ideal where all distortions are minimized to be around a 60 kHz. sample rate with 22 bits of dynamic range. From a digital signal processing standpoint double either or both is sometimes necessary in order to end up with minimal artifacts below 20 kHz. Unfortunately the consumer electronics industry dictated our sample rates and not the experts. There's no free lunch, the more times the numbers are calculated, the less accuracy you end up with. Several plug-ins that require an up-sample/down-sample cycle at 48 but not at 96 will be more accurate processing 96k audio. The way I think of it is selecting where the conversions will happen. If you record and process at 96k, there will probably be fewer conversions and hence more accuracy by the time you end up at your final delivery sample rate.
#95
Ian Shepherd does a good job explaining it in layman's terms here:
http://productionadvice.co.uk/no-sta...digital-audio/ The moving fingers example isn't really very parallel but I guess it kind of works as an introduction to thinking about the subject. Apart from that, and within the limits of simple, straightforward recording and playback, most of what he says is right on, I think.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#96
On the other hand, if my final product is video, I'll use 48kHz, 24bit or 32 bit fp. Again, if I want to go higher, 96khz or 192. (Again, two big if's. The vast majority of my work is bounced down to 44.1/16. Occasionally mp3). I've seen a lot of heated debate, but as I said, you have to use SRC if you're recording at 48khz, then converting to 44.1 when you bounce down. I suggest investigating the results, if seen a number of online tests. To my ears, unless it's something like Izotope's SRC, I notice distracting artifacts in the upper harmonics when converting 48 to 44.1. When the whole band is kicking-not so much. But on sound tests involving a single sine wave for example--definitely noticeable. Again, mho. Tim |
#97
It's all about minimizing the artifacts below 20kHz. and not capturing audio for bats!
There is a point of diminishing returns due to the speed limitations of chips so higher is not necessarily better. The idea that final SRC adds an extra process also isn't necessarily true if the processing involves any oversampling that is disabled at 2X. The MDW eq. is a good example of this. I do everything I can at 48 or 96 because the CD's days are numbered and conversion from 48 to 44.1 sounds better to me than conversions from 44.1 to 48. We never really know the future importance of what we are working on so it makes sense to me that working at the highest practical level of quality is always appropriate.
#98
Thanks Bob; this makes good sense. I've been using 44.1 for years because of CDs. Now I think I'll switch to 48 (or 96). Another good reason is that video editors typically prefer audio @ 48.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#99
Used to do 48khz 24 bit, but now with newer hardware etc. I am doing everything at 32bit 96khz and then convert down from there, unless it's just not worth it. I, however definitely hear the difference in my room after years of doing lower sample rates. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
#100
There's no advantage in recording to 32 float files over 24 bit. There is an advantage to 32 float when calculating files with DSP such as Audiosuite or bouncing. The session setup window allows you to change it back and forth during a project.
going higher than 10.6.3 | viaspiaggia | Post - Surround - Video | 2 | 06-23-2011 04:41 AM |
Can I get mp3.dll from 6.7 or higher? | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-13-2006 01:54 PM |
Anyone running higher than OS 10.3.4 with 001? | duderonomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2005 07:59 PM |
Anyone use JAM v.2.6 with OS 9.1 or higher?? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 09:38 AM |
Higher Gain | Tommyboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-22-2000 06:48 AM |
