Old 07-16-2013, 06:47 AM
markprator markprator is offline
Default ANY comp/gate with duck feature?
I'm running PT10, HDX, mac mini. I've just installed the UA Octo ultimate as well. Does anyone know of a comp/gate/limiter plug in with a "duck" feature?
....and don't say Drawmer......I can't use it now. Blows my mind I can't find this simple option......thanks, all!
Old 07-16-2013, 06:52 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: ANY comp/gate with duck feature?
Drawmer would have been your best bet. I myself am still hoping Avid will get it to PT11... :P
Janne
Old 07-16-2013, 06:56 AM
you said Drawmer.....
Old 07-16-2013, 08:56 AM
Mista Min Mista Min is offline
Bwahahahaha!!
Old 07-16-2013, 11:30 AM
conleec conleec is offline
WaveRider works well, but the 64 bit AAX isn't yet here. It will be shortly, though.
Chris
Old 07-16-2013, 01:29 PM
ilovemyssl ilovemyssl is offline
So you're looking to "duck" the audio on one track keyed by the audio on another track?
Avid Dyn3 Compressor, Avid Channelstrip, Focusrite ff D3 all do this..
  • On the track you want to use as the "key" or "trigger", setup a bus send to "Bus 1" and set the send level to 0dB .
  • Open one of the plugins listed above on the track containing the audio you want to duck and set the "Key Input" (the picture of a key in the plugin header - how ingenious) to "Bus 1".
  • Then click on the "key" button (next to "Sidechain" on Dyn 3 Compressor) and set ratio and threshold to taste.
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 07-17-2013, 01:42 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
sonnox
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Noise Gate feature request to vote for mikefont Eleven Rack 1 11-26-2010 08:37 AM
'Duck' style side-chain gate. Ootini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-18-2004 10:25 AM
comp/gate before pro tools jwbyrd16 General Discussion 2 10-10-2002 09:35 AM
Comp/Gate before PT jwbyrd16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-09-2002 04:45 PM
Vocal Expander Gate with a Comp. Sounder Tips & Tricks 1 03-12-2001 03:54 PM
