Old 04-30-2001, 08:19 AM
markprator markprator is offline
Default ATTO, FWB, 5.01, and 5.1 problems!
I'm currently working on three TDM mac systems. One with v5.1, and two with v5.01.
It seems that drives formatted with FWB aren't behaving properly with v5.1. Digi is telling me to format with the ATTO utility. Interesting......will lead to problems when I upgrade to v5.1 on all systems, especially when I'm dealing with archived sessions from previous versions. Could this be a SCSI card issue? Or a formatter issue? Anyone?
Old 04-30-2001, 11:54 AM
swablar swablar is offline
Default Re: ATTO, FWB, 5.01, and 5.1 problems!
Could be a little of both.
If you use the Atto scsi card and FWB formatted drives, you should really do 2 things.
1. Enable the Atto EPT 2.3.2 extension.
2. Select "Inhibit driver" on each drive from within the Atto Utility.
Also, I've seen a lot more "scsi voodoo" with FWB 4.0 than 3.0.2. So, I would stick with FWB 3.0.2 or Atto 2.3.2.
If you only use these drives on your system, then use Atto EPT and forget the Inhibit driver thing. Also, remember, when using the Atto EPT utility to initizialize your drive, select "erase Disk" prior to initializing. thsi erases any old formatting drivers buried on the drive.
Also, Atto firmware on the card should be 1.44 or 1.63 (especially with Tape back drives and Removable drives).
good luck
OS 10.4.3 scsi atto problems Cawbaby Pro Tools TDM Systems (Mac) 5 03-29-2006 04:39 PM
problems with atto on Dual gig mdd dvillage Pro Tools TDM Systems (Mac) 0 02-01-2003 08:17 AM
ATTO B&W G3 problems FDurrett Storage Subsystems 0 05-18-2001 09:48 PM
ATTO Card problems MARVINBASS Storage Subsystems 0 11-08-2000 12:25 AM
ATTO Driver Problems anyone? David McRell Pro Tools TDM Systems (Mac) 8 08-12-2000 07:09 AM
