Old 08-27-2020, 12:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Odd things happening with icon driver bundle on Mavericks
I’ve had to do a complete reinstall of everything and had to go to Mavericks for UAD plugin compatibility. Everything has been running fine on mountain lion with the icon! But my first full session on Mavericks and after a few hours the EQ and Dynamics sections stopped working? I thought it was a physical issue. Console broken. Cable off or power supply issue. Then ran test on the console and everything worked, ran Vegas test mode etc. Then I thought I would boot up the old mountain lion system and everything worked. Back to Mavericks still not working. Trashed PT prefs and back working!! Next day the centre meters stopped working. Went back to mountain lion all ok. Back to Mavericks and they’re working again? Seems odd the just sections of the console stop working and require prefs to be renewed or to boot up the old system to get them back working.
Also since Mavericks install the monitor section says Xmon off all the time. Might be something else causing this.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-28-2020, 07:25 AM
francois's Avatar
francois francois is offline
Default Re: Odd things happening with icon driver bundle on Mavericks
Probably an issue with Maverick, anyway you could up to Yosemite ?
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
HD I/O - seriously strange things happening. sircletus Pro Tools HDX & HD Native Systems (Mac) 4 04-18-2024 06:28 AM
Strange things are happening! Terry Wetzel Windows 5 03-03-2013 10:36 AM
Weird things happening kyluigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2012 05:57 PM
Stange things happening Earl Kurburski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-07-2011 03:14 PM
Very bad things happening CStern Pro Tools TDM Systems (Mac) 3 02-12-2000 06:07 PM
