Old 10-19-2017, 06:04 AM
cebolao cebolao is offline
Default eucon 3.7 quits unexpectedly
it does not work at all on my system
it quits unexpectedly as soon as i open protools
tried 15 times, did restart the system couple of times
mac os 10.10.5, protools 12.5.2
Old 10-19-2017, 06:05 AM
Default Re: eucon 3.7 quits unexpectedly
back to version 3.6.1
Old 10-19-2017, 06:42 AM
EddieJones's Avatar
Sorry, There was a problem with the installer. If you uninstall using the uninstaller in the Applications folder and reinstall you should be good. We are in the middle of updating the download files as we found the issue and fixed overnight.
Old 10-19-2017, 08:55 AM
EddieJones's Avatar
The new installer is now in MyAvid accounts and will be posted to the older MyArtist site shortly. Heres a temporary link for faster access EuControl 3.7 fixed
Old 10-19-2017, 11:36 AM
thank you very much!
it works now
i can see the trim mode!
Old 10-22-2017, 01:42 AM
[email protected] info@giampaolotestoni.com is offline
New Eucon software 3.7 (138j problem with last Logic Pro X 10.3.2, El Capitan. When I open Logic Pro X , a window pop up say: Incompatible EuCon version. Please update EuCon.
Current EuCon version: 4.0.3 build 138
Minimum EuCon build: 65.916
under these written there are three buttons, first say Launch with EuCon, second say Launch without EuCon and third say Quit.
I’ve tried to reinstall, even with clean script, I delete Logic preferences but always same window every time. After I click first button, Logic works perfectly with my Artists Control and Mix. Any suggestion?
Old 10-22-2017, 02:00 AM
https://www.dropbox.com/s/yn8ruxddwr...%20X.tiff?dl=0
Old 10-23-2017, 10:12 AM
Loungery Loungery is offline
Same Problem here! Any ideas?
Old 10-23-2017, 10:52 AM
EddieJones's Avatar
We changed the way EuControl builds (now with S6 as we merge the code) This has changed the build numbers. Apple need to remove that notice and we have informed them. Just click run with EUCON until that happens its OK.
Old 10-23-2017, 10:53 AM
Thanks so much for that information. Alright got it. Working much better the new version!
Logic Unexpectedly Quits when Loading EUCON Support holymusicproductions Artist Series 0 03-19-2013 10:17 PM
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
PT 8.03 quits unexpectedly NOGCHOPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-04-2010 11:46 AM
PT 7.3.1 unexpectedly quits schulze Pro Tools TDM Systems (Mac) 0 04-19-2008 12:27 PM
Unexpectedly quits Stig Eliassen Pro Tools TDM Systems (Mac) 4 05-03-2005 01:34 PM
