Re: Do you have to have a 7200 rpm hard drive to run Pro Tools 10?
They double as ambient noise generators and space heaters.
Its nice that the WD Black drives are fast and quiet for the studio.
True but even then I moved my computer out of the studio a long time ago.
Do any PC's come with 7200 rpm hard drives? I will be making a choice to buy a new rig within the next 6 months. I am definitely using an SSD for C: drive though.. Maybe it is a stupid question, haven't had the need to shop around in years. Thanks!
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers |
Actual workstations for HP or Dell will probably sport hi performance 7200 drives. With even faster 10-16k drives available in some cases.
Given most computers from the big OEMs often come with a fairly generic drive image with tons of factory bloatware installed to the C drive I'm a big advocate of actually installing a fresh version of Windows to a blank 7200 RPM drive. I'm fairly convinced that its these unoptimised drive images that often cause issues and keep some of the factory machines from running PT as smooth as they should. And its one of the reasons that the custom DIY machines do better.
That's just a hunch. I have no particular data to back that up. And if my new laptop or tower was running PT great out of the box I doubt I would reformat it. But if it was giving me issues and the hardware was known to be working with PT I'd probably start with a fresh install of Windows and only PT. If only as a troubleshooting step. Dell and HP have both had issues where there machines blue screened after service packs. In both cases they had used drive images with registry settings and or driver for the wrong CPU manufacturer. IE the drive image was optimized for a AMD processor and the machine actually had a Intel chip. And Vica Versa. I believe your better off installing Windows and let it install the right drivers and hardware abstraction layer etc for your actual hardware. I'm mentioning this not to derail the thread but because it sounds like you were going to go looking for a off the shelf computer. Its just something to keep in mind. /end derailment. Well almost. I have seen some pretty obvious increases and decreases in boot when cloning from 5400 to 7200 and vica versa. Bottom line is I won't buy a 5400 RPM drive unless its the only available choice. They are S L O W.
I am more than happy with the amount of years and performance this Toshiba Satellite has given me. I bought it in 2007-08. I just don't want to be limited with the amount of VI's and heavy plugins on my future sessions, so for those reasons, I know that I will be making a purchase (most likely toshiba again) within the year. So as far as my C: drive, it will definitely be an SSD and then I will have to look into making sure they offer a 7200 or greater additional Hard Drive for my audio. I actually bought my rig directly from Toshiba and got to choose the specs. This time I know exactly what I need, and have another 7 or so years of Protools troubleshooting experience. I am pretty confident that it will work out great. I just was wondering if these 7200 rpm drives are common requests these days for laptops? -peace and thanks -Lou
I've been using a 5400 rpm external drive for over a year now and have not had one issue with it yet... Maybe I'm just lucky though...
me too. a WD passport external black
Is this 7200 rpm external hard drive | ReynaldoPena | Windows | 1 | 11-20-2012 07:54 AM |
2.5" 7200 hard drive | ThaRhythm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-07-2010 11:54 AM |
7200 rpm vs 10000 rpm hard drive | akewldewd | Storage Subsystems | 2 | 09-26-2010 08:55 AM |
FW Hard Drive Help? 7200 Fantom drive not working | 72reissue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-10-2005 02:28 PM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
