Can\'t enter memory locations with \"enter \" key?
I recently upgraded to 6.7, and I can no longer add a marker using the enter key on the fly. I think I'm probably doing something wrong or have a goofy preference... Any help would be appreciated.
1Ghz Powerbook 762mb Ram 002 Rack PTLE 6.7 |
Re: Can\'t enter memory locations with \"enter \" key?
Which Enter key are you using..? You must use the one on the Numeric Keypad. On a Powerbook that means you need to hold down the Fn key I believe.
Rail
Thanks for that speedy reply. I tried using the fn key instead and still no dice. It's weird I'm using the only enter key on the keyboard, that I've always used.
On my laptop you must hold down the Fn key while pressing the Enter key.
The regular Enter key takes you to the top of the session. What language is your OS and keyboard? Rail
Yeah holding down fn while pressing enter doesn't work. Language is US English, OS 10.3.7...just upgraded from 10.3.4 hmmm
On my PowerBook I have to press a certain F-key on the top row. Since it's not in front of me I can't tell you exactly which one, but it's near the center. I think it's labelled KEYPAD or NUM LOCK. Whatever it's labelled, it's the one the lights up with a green light to indicate it's active. Now the "keypad" is active and the "enter" key is now the "keypad enter" key. You can also use the alpha keyboard as a number pad -- the keys like "j, k, l, or ;" become number keys.
Sorry I can't be more specific than that. I'm at work and my PowerBook is lounging at home.
PowerBook G4 1.25 gHz with 2GB RAM, OSX 10.3.7, PTLE 6.7 with MBox, 2 LaCie d2 FW800 drives, Reason 2.5, Ableton Live 4, Waves Gold Bundle |
Enter in/out bug | jjsoundoc | Post - Surround - Video | 1 | 10-18-2012 04:47 PM |
enter will not create memory location | cananball | Post - Surround - Video | 3 | 04-12-2012 07:41 PM |
Enter REC during playback? | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2008 01:12 AM |
003 Enter Button Fails To Create Memory Locate | emptysea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-12-2007 11:56 AM |
Why do I always have to enter my #s again and agai | joo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-16-2005 07:16 AM |
