Old 03-29-2010, 06:48 PM
fixitinthemix fixitinthemix is offline
Default low static noise in PT 8
SiSoftware Sandra
Computer
Model : Gigabyte X58A-UD5
Workgroup : WORKGROUP
Host Name : elovsson
User : Anders Elovsson
Processor
Model : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte X58A-UD5
BIOS : Award (Phoenix) F4 02/11/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.43GHz (4.86GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Total Memory : 6GB DIMM DDR3
Memory Bus Speed : 2x 540MHz (1GHz)
Memory Module(s)
Memory Module : Corsair CM3X2G1600C9 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : NVIDIA GeForce GT 220 (32 SP, 1GB DDR3, PCIe 2.00 x16)
Graphics Processor
Storage Devices
WDC WD6401AALS-00J7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 596GB (C:)
WDC WD6401AALS-00J7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 596GB (D:)
TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
Hard Disk (C:) : 293GB (NTFS) @ WDC WD6401AALS-00J7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Hard Disk (D:) : 596GB (NTFS) @ WDC WD6401AALS-00J7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : Giga-Byte High Definition Audio Controller
Audio Codec : nVidia 000Ah
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller #2 - Packet Scheduler Miniport
Network Adapter : Realtek PCIe GBE Family Controller - Packet Scheduler Miniport
Network Adapter : D-Link DWA-140 RangeBooster N USB Adapter(rev.B2) - Packet Scheduler Miniport (Ethernet, 26Mbps)
Wireless Adapter 1 : D-Link DWA-140 RangeBooster N USB Adapter(rev.B2) - Packet Scheduler Miniport (AES-CCMP, 26Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
I run pro tools 8.0.0 on XP sp3. I installed w7 first but it didn't work so I removed and went eith XP instead.
I have a constant low noise on my speakers. Sounds like a mix between white noise and a modem. It sounds like that even before I launch PT 8 if the fire-wire cable is connected to my digi 002. There's no noise in the headphones. This is taking so much time and work..
Any idea?
Old 03-29-2010, 06:51 PM
YoRugMan YoRugMan is offline
Default Re: low static noise in PT 8
I would first update to 8.0.1cs1 - this is the best version of PT to use with XP SP3.
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us.
Old 03-29-2010, 06:57 PM
cwsand's Avatar
cwsand cwsand is offline
Originally Posted by fixitinthemix View Post
SiSoftware Sandra
Computer
Processor
Speed : 3GHz
Type : Quad-Core
Computer
Chipset
Chipset
Memory Module(s)
Video System
Graphics Processor
Storage Devices
Peripherals
Printers and Faxes
Network Services
Power Management
Operating System
Any idea?
What kind of monitors/speakers and/or amp do you use? Sounds like a possible grounding issue to me between your 002 and amp. Is all your equipment powered off the same circuit? Also, do you have your onboard soundcard connected to your 002 in any way (like to the Aux In)?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 03-29-2010, 07:47 PM
Jenk2k Jenk2k is offline
Make sure you're running TRS (tip ring sleeve......) cables to your monitors. This will kill all the noise for most people.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 03-30-2010, 07:20 AM
The TRS cables fixed it! Thanks a lot!
So I think I'll upgrade to 8.0.1 cs1 How can I make a back up of my system, to revert to if the upgrade doesn't work? (I'm a noob)
Old 03-30-2010, 10:24 AM
use either norton ghost or acronis true image
Old 03-30-2010, 10:44 AM
TOM@METRO's Avatar
Afetr using both Ghost and True Image I feel The later is best suied for cloning a system drive with Pro Tools and 3rd party plug-ins involved. Authorizations are an issue with Ghost. Always keep a clone drive handy so you can be up and running in seconds if there is an issue,
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
static white noise Rawer macOS 15 03-31-2013 01:16 PM
Static noise DiegoFox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-28-2011 03:00 PM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 04:06 PM
7.3.1 - static noise after using for a while dcrann11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-21-2007 06:11 PM
Loud Static Noise Billy Bad Ass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-11-2005 09:21 AM
