More input channels needed
Ok, so I have PTLE 7.3 with the Mbox. I realize that the Mbox is the operate key for the software. No problem there... So, given this, can I plug in another preamp and record tracks from it too? Say something like a Firebox for example which would get me 8 more inputs so I would have 10 mic preamps then?
Thanks
Staying out of Trouble Is Easier than Getting out of Trouble |
Re: More input channels needed
Looking at the LE Comparison Guide found at the bottom of this page:
http://www.digidesign.com/index.cfm?...0&itemid=23596 it looks like if you have a regular Mbox2, you can have 2 simultaneous analog inputs and 2 S/PDIF inputs running at the same time, for a total of 4 inputs. The Mini only allows 2 simultaneous analog ins and the Mbox2 Pro allows 6 simultaneous inputs. My Mbox1 allows either 2 simultaneous analog inputs OR 2 simultaneous S/PDIF inputs, but not both at the same time like yours does. You could always use a multichannel mixer and submix as many channels down as you need to a 2 track bus to take the stereo output into 2 channels of your Mbox. bilco |
yeah, the mbox is the only piece of digidesign hardware that you cant add on to or even bypass the pre-amps and run a different pre-amp through it. with 002 and 003 you can add on if you want though.
www.barnabas.com Barnabas MultiMedia |
Not enough ASIO output channels available.at least 2 channels are needed. | kudca | Getting Started | 1 | 05-26-2013 04:05 PM |
Input Channels??? | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-11-2008 06:57 AM |
More Input channels | José Luis Díaz | Pro Tools M-Powered (Mac) | 2 | 01-09-2007 03:06 PM |
Input into HTDM Channels? | Logichead | Pro Tools TDM Systems (Mac) | 3 | 12-31-2004 03:29 AM |
Help, not seeing input in channels 3 and 4 | Dennisfootpole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-25-2001 12:28 AM |
