Old 11-01-2004, 08:08 AM
FullFreq FullFreq is offline
Default MMC
If I use MMC can I link 2 programs like PTLE and Sonar on the same computer? Basically I want to sequence MIDI with Sonar and use PTLE for audio.
Or does there have to be a physical MIDI connection?
Digi 002R Factory Bundle
P4 2.4 Ghz 1MB Cache
1GB PC3200 Dual-Channel DDR RAM
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Old 11-01-2004, 08:44 AM
BIG D BIG D is offline
Default Re: MMC
Rewire is really the only happy way to get another application to work in residence with PTLE. Pro Tools likes using up all the resources and of course the sound device (002,Mbox etc.)
I don't think Sonar can run in a rewire config. Before my Protools days I used to use PARIS and LOGIC together but they never really locked in SYNC very well.
Hope that helps,
BIG D
INTEL QUAD XEON
INTEL S5000XVN serverboard
4 gig Fully Buffered Ram (About to add more)
3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green
NVIDIA Geforce 7300le,
Command 8,HD2,192,Massive Pack 4
Windows 7 64 bit PTHD 9
Old 11-01-2004, 03:31 PM
shanabit shanabit is offline
Default Re: MMC
DO NOT use the IAC bus to connect the two. See my post on midimadness. Ill be re-loading everything soon if I cant get help.
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
