Old 10-26-2004, 11:50 AM
Nick Rogers Nick Rogers is offline
Default MIDI problems with 6.4
I am at a complete loss with my current problem... hopefully someone can help me. I know Pro Tools pretty well, and am confounded right now. My problem is this: I'm trying to set up an M-Audio Keystation USB Midi Controller to work with Pro Tools LE 6.4 with a Digi 001. I installed all drivers necessary, selected the controller as my main Midi Device for Windows, and opened Pro Tools. Created a MIDI track and an aux track. Inserted the Pro-53 on the aux track, turned the fader up to unity, set the input of the midi track to "all", output of aux to Analog 1-2. However, the output for the midi track will not allow me to set to the Pro-53, but it will not let me select a channel. It only says "Channels not activated" or something similar (do not have pro tools open at the moment). The controller works fine with the Pro-53 in standalone mode, but Pro Tools will not for some reason connect to it. I can pull up the instrument on the aux and use the mouse to press the keys, however. It is audible and works great that way... however, the midi controller has no effect on it whatsoever.
I thought it may have been a problem with the Pro-53 so I tried Reason. I set the output of the midi track to Subtractor Channel 2 and set the Midi In Device in Reason as the controller for Channel 2. Still nothing.
Any help on this would be greatly appreciated. I am a longtime user of Pro Tools, but have never had to set up a midi instrument before. Now that I am just getting into it, I feel like a total newbie again.
Thanks in advance,
Nick
Old 10-26-2004, 12:02 PM
Default Re: MIDI problems with 6.4
You've set the input to the MIDI track to ALL, which will only work IF your controller shows up in the list of input devices. If your controller doesn't show up in the list of available devices, something else is wrong.
'No Channels Activated' is just noise, ignore it.
Quad 2.5 G5, 4.5G RAM
spkguitar's Avatar
Have you record armed the MIDI track?
Old 10-26-2004, 12:57 PM
FullFreq FullFreq is offline
I've been having similar problems lately with my M-Audio Radium 61 controller and PTLE 6.4. I can use the Radium in keyboard mode and play my Korg MS2000 fine, but having PTLE communicate with it isn't working correctly.
Digi 002R Factory Bundle
P4 2.4 Ghz 1MB Cache
1GB PC3200 Dual-Channel DDR RAM
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Old 10-26-2004, 01:33 PM
Wouldn't you know it would be something as simple as arming the track? Thanks for the help guys, that was quick response and the issue is now resolved. For as much as I know about Pro Tools, you would think I could figure out that the MIDI track needed to be armed. Oh well, c'est la vie.
Thanks again,
Nick
Old 10-26-2004, 01:58 PM
See I can hear the Korg when I have my M-Audio controller running in keyboard mode. But when I use the USB MIDI out of the M-Audio I don't hear anything. It might not be PTLE related. I might have to reinstall the drives for my M-Audio controller.
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Problems with Midi sound / Midi Controller joe_04_04 MIDI 2 07-16-2009 12:43 PM
MIDI Problems with Axiom 25 MIDI Controller jasonguitar Pro Tools M-Powered (Win) 12 04-03-2007 10:04 AM
Help...Problems with midi my cardboard box 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-27-2004 06:35 PM
MIDI NOTES DISSAPEAR!!?? WIERD MIDI PROBLEMS ManhtnProjct Pro Tools TDM Systems (Mac) 2 10-29-2001 08:39 PM
