Old 10-26-2004, 09:35 AM
reshp1 reshp1 is offline
Default Multiple monitors for Mix and Edit windows?
Hey guys,
Are any of you using separate multiple monitors for your mix and edit windows.
Is there a way to "unlock" the mix and edit windows from the main protools windows, so they can be moved outside the protools window? like with the transport window. My problem is that when I maximize the protools window, it only maximizes to one of the monitors, not stretched across both. I can manually stretch it across both, but it's a pain. And even after I do that, there's no "tile windows" option, so I have to manually re-size the mix and edit windows to fill up each monitor. Also a pain, and PT doesn't "remember" the locations each time, so if I open a new session, I have to manually resize everything again.
Anyone know a good work around for this?
Thanks
Mike
Old 10-26-2004, 11:48 AM
Parisstudio Parisstudio is offline
Default Re: Multiple monitors for Mix and Edit windows?
I had the same problem until I updated PTLE to the latest software, now it automatically opens two both screens.
Eric M.
Old 10-26-2004, 11:52 AM
Thanks for the reply
I have v6.1, going to v6.4 would do it?
Mike
Old 10-26-2004, 01:21 PM
FullFreq FullFreq is offline
Yeah I have 6.4 and once I set everything up initially, doing what you talked about as far as stretching the window across both screens, resizing the mix and edit windows, etc. Then anytime I launch PTLE it goes right to those settings. I wouldn't work any other way to be honest. It's so much easier to have one window for editing and the other for mixing.
Digi 002R Factory Bundle
P4 2.4 Ghz 1MB Cache
1GB PC3200 Dual-Channel DDR RAM
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Old 10-26-2004, 02:11 PM
er1c er1c is offline
If you have Matrox Graphic Card try CTRL+Mouse Button on Maximise Window Icon, it will maximise the ptle window in the two screens.
Can I get MP 9 Mix/Edit windows on seperate monitors? d-rok Pro Tools M-Powered (Win) 1 06-20-2011 03:21 PM
dual monitors separate mix and edit windows? bonzerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-14-2010 10:24 AM
edit multiple regions bad_ben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-01-2009 07:55 PM
How to setup seperate Mix and Edit windows on Dual Monitors G.roots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2007 08:11 PM
Mix and Edit windows won't move across dual video monitors mrllnfn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-27-2007 05:17 PM
