Some Strike kits won\'t load
Picked up Strike today. Got everything running, did the most recent update, and from what
I could tell, it's great. Liked the sounds, worked really well inside PTLE, nothing exploded or caught fire. The only problem I had was, some of the kits wouldn't load. I must of missed something in the manual. Is there a "quick start" guide for it? I was just trying to set up a kit that I could assemble from the various presets, but I couldn't figure out how to do it. Any help would be most appreciated. |
Re: Some Strike kits won\'t load
Yes, Quick Start, starts on Chapter 5 of the Plug-In Guide and you should review the Configuration Window section under Strike Parameters also.
filosofem
Aaron Mulqueen - 001 HD Native |
Figured it out, in case this happens to anyone else. For some reason, when
I loaded the plug in, half the sounds went to my system drive instead of the drive I specified for the samples. Dragged them over to the other drive, works great. |
PT 9.02 & STRIKE! Losing Kits | LightWing | Virtual Instruments | 8 | 03-17-2011 01:35 PM |
PT 9.02 & STRIKE! Losing Kits | LightWing | Windows | 0 | 03-13-2011 09:18 AM |
Strike - Saving Your Own Kits | td7474 | Virtual Instruments | 3 | 08-17-2009 06:02 PM |
Additional Strike kits? | rinky | Virtual Instruments | 13 | 09-03-2007 05:53 AM |
Stylus RMX: can't load kits | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-17-2005 03:06 AM |
