Waves StudioRack - example of good plugin chain presets implementation in Pro Tools
Well, people have asked for plugin chain presets in Pro Tools since the beginning of time. And here we have it - although for Waves plugins only, the way it works is really nice. Automation works, cmnd+ctrl+click on parameters works, Preview / Capture works. After several hours of testing it is very usable with no noticeable issues. It greatly enhances workflow in Pro Tools for people that rely mainly on Waves plugins.
I think this could be the way Avid might implement plugin chain presets. Think: a plugin more or less the same as Waves StudioRack but for all AAX plugins.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
Re: Waves StudioRack - example of good plugin chain presets implementation in Pro Too
I disagree completely.
I want plugin chains and the ability to load them etc, but I DO NOT want them all buried into another "interface" in the GUI. PT has 10 inserts for a reason. I want each plug on its own insert, freely viewable and accessible on my ICON. I guess it's cool for Waves' plugs and the same will likely be true for Slate's VMR, but I don't think it's a good way for Avid to handle this in PT overall. |
What I mainly like about this implementation is that I can recall a preset that contains changes in all 8 plugins and Pro Tools sees it as a change in automation parameters of all plugins. Using the following: Preview mode, copy/paste plugin settings (cmnd+shift+C/V) and write automation to selection is great. I think it's quicker than using Capture buffer. I agree with your points. I also think mine are valid too. It would be nice if both could be achieved.
The problem is, if Avid does something similar, then you've got two systems inside PT. no bueno.
Well, I think I got excited about having plugin chain presets right now with Waves :)
"PT has 10 inserts for a reason. I want each plug on its own insert, freely viewable and accessible"
+1
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Basically: functionality of StudioRack without a separete window is something that I would like to see. With smooth recalling settings of all 10 inserts in one click.
Ok, so now we agree.
Not like Waves. Although Avid, being in complete control of PT unlike Waves, could have some sort of global plugin view that would be similar. |
I haven't downloaded or installed it yet but I like that the output of each plugin has it's own metering....very useful
I'm really hoping I'm mistaking here, but if you look on waves web page, there's prices set for the eMtion st mixer 450$, so unless I'm mistaken here, it seems that you need to buy the software on top of buying the hardware? Becoming expensive for something that will add layers of routing over your recording and mixing...
Waves Studiorack | Righty27 | AAX Plug-ins | 375 | 02-19-2015 01:23 AM |
Waves StudioRack Native plugin | rjmurry | Pro Tools 11 | 2 | 07-23-2014 02:22 PM |
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
Plugin Presets - waves | ScreaminRick | Pro Tools 9 | 2 | 09-23-2011 06:21 PM |
Any good sites for trading plugin presets?? | Andrew_k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2004 08:27 PM |
