Loading Plugins at Startup is Slowww
As of a few days ago the PT startup screen that loads plugins takes a couple minutes. Nefore the status bar would fly to the finish line in seconds. I havent installed any updates, plugins or anything else that would affect PT. And yes, I've tried reboots of everything.
Has anyone ever run into this and found a fix? Thanks. |
Re: Loading Plugins at Startup is Slowww
Any other drives or USB devices connected? Chris
What Jack said and or a bad/old/demo pugin that causes the delay by ot communicating properly. Look over your plugin folder when you have time and also delete the plugin list (.plist) in preferences folder and let PT re-read in all your uptpdate pugins and that will be slow but should improve after it has repopulated all your plugins.
PT12 crashes during startup when loading plugins | MikeV252 | Windows | 2 | 12-06-2015 07:01 PM |
PT 11.1.3 and 10.3.9 Hang on Loading Plugins at Startup | bluezone8 | Windows | 3 | 06-18-2014 03:50 AM |
VST not loading in the STARTUP ?? | sebdj | Pro Tools M-Powered (Win) | 3 | 10-03-2008 09:23 PM |
Pro Tools hanging on startup at "Loading Plugins" | Eric Gale | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-03-2006 06:35 AM |
ilok plugins not loading on startup? | 8trackmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-23-2006 03:40 PM |
