HEY DIGI- 1622??
I need to know, is the 1622 i/o actually shipping?? If so, could you please send some to Rainbow Music. They said they haven't received any yet, and mine has been on backorder for a while.
Also, is it true that you MUST use DAE 5.0 with it? Several dealers told me this. If so, how about putting that fact on your 1622 product info page at: http://www.digidesign.com/prod/1622/indxdata.html All it says for SYSTEM REQUIREMENTS is: Digidesign-approved Pro Tools|24 or Pro Tools|24 MIX system Digidesign-approved Mac OS or Windows NT CPU thanks |
Re: HEY DIGI- 1622??
I got mine last week. FYI.
Michael |
The 1622 does require DSI 5.0, since it was written after PT 4.3.1 and 4.3.2 were. Both of those Pro Tools versions will work with DAE/DSI 5.0 if you install Pro Tools 5.0 first, then open PT 4.3.1 or 2.
I'll check next week when I'm in the studio to see if the 1622 shows up in the hardware choice using that setup, and add those findings to the System Requirements on the 1622 web page. I believe the 1622 box does say "Pro Tools 5.0 required", but I'll try to get some further detail before adding that to the web specs. You're right, that should be made clear. ------------------ Bruce Paine eMarketing
Administrator Avid Pro Audio Community |
1622 vs. 822/20 | Philee | Digidesign Hardware & Software | 7 | 09-27-2010 08:45 PM |
Need help! 1622 or two 888/16 | Kuleone | Pro Tools TDM Systems (Mac) | 3 | 01-17-2006 09:48 PM |
Advice Please - Rosetta 800 and Digi 1622 issues? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 4 | 04-03-2005 09:34 PM |
Is Digi001/Protools Le compatible with Digi 1622 for more intputs. | littlechu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-21-2002 03:17 PM |
To Digi about my 1622 | M2E | Pro Tools TDM Systems (Mac) | 1 | 11-19-2001 12:41 AM |
