Old 11-19-2023, 11:40 AM
bzone bzone is offline
Default UAD card Plug-Ins to Spark
Any one do any experimenting with the new M2’s with and without the cards? Delay times, load times, audio quality? Thinking during the Holidays to break things down and get the new Mac Pro and get rid of the old cards, now that everything is getting so fast. Using for mixing only , not on any UA converters or input devises here, Burl Motherships for AD/DA and outboard for tracking. Any discrepancy ‘s, pros and cons that you have found? Thank you.
Old 11-19-2023, 12:57 PM
s.d. finley s.d. finley is offline
Default Re: UAD card Plug-Ins to Spark
I am not on Apple Silicon but am using UADX native versions of my UAD plug ins and I will say you can get MORE of the native plug ins than the UAD versions. Latency is negligible for mixing. Not all UAD plug ins are available for UADX, yet. I am enjoying the Massive Passive as UADX as with the UAD that plug in uses 75% of one UAD2 dip chip
IF you already have UAD plug ins you have the same ones in UADX for FREE
sdf
www.sugarhillstudios713.com
Old 11-19-2023, 01:00 PM
^^^ exactly, most people will be way better off losing the old UAD license dongles aka DSP cards and just running the plugins native.
Old 11-21-2023, 03:05 PM
noah330 noah330 is offline
I have a Mac Studio (M1) and use the UAD hardware and Spark. There's no difference, but a few of my favorite plugins (Ampex) are only on UAD (for now).
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 11-22-2023, 06:09 AM
martthie_08 martthie_08 is offline
bit of a shame there is no switching between DSP and native within the plugin. I do find my octo card takes down overall CPU about 20% when maxed out as compared to having everything run native. On the other hand, offline bounce is much faster with no UAD DSP present in the session. There are still a good number of UAD DSP plugins (Ocean Way, SSL, 480L, etc) that I frequently use so at this point it's a mixture...
Old 11-22-2023, 08:35 PM
audiolex1 audiolex1 is offline
That is a bummer, but I'll put reverbs and delays on DSP and EQ comp on native unless I want something specific.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 11-23-2023, 10:12 AM
cwsand's Avatar
cwsand cwsand is offline
Yes it is. I'm currently using an Octo card and started using Spark recently and the combination is working well. I mainly use native plugins that I don't have individual licenses for and use as much DSP as it can handle. Wish I could easily switch between the 2 without having to replace the original plugin with a new instance. Another thing that would also be nice is if the presets were interchangeable!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
HTML code is On
Spark appledude Virtual Instruments 0 04-02-2018 08:28 AM
Arturia Spark 2 - $100|Arturia Spark EDM & Vox Continental including eLicenser - $100 hatepop Buy & Sell 2 10-26-2014 06:46 AM
Problems using Spark XL w/Direct Connect Plug isolde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2002 05:51 AM
has anyone tried spark xl to use vst plug-ins in pro-tools graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-26-2001 07:41 AM
Spark Walter O'Neill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-18-2000 10:28 PM
