Old 11-17-2023, 05:14 AM
Treblecorp Treblecorp is offline
Default Static sound
ProTools Artist
Mac Studio M1
Volt 2
On one sound recording, when bouncing the mix, a static sound persists.
I checked another song and bounced a mix to a single track and there were no issues.
So it is only happening with one sound recording not others.
Everything is normal when I play it back through the monitors.
I tried changing buffer size, and the issue still persists.
Old 11-17-2023, 07:39 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Static sound
Are you using Offline Bounce? Do you have any open Aux tracks in the session?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-17-2023, 08:14 AM
There are no open aux tracks. When I bounce, I go to File > Bounce. I haven't changed anything in my workflow
Old 11-17-2023, 10:02 AM
sw rec sw rec is offline
Sounds “song specific” to me. What do your levels look like on your Master fader?
Old 11-17-2023, 10:06 AM
Does this happen for online and offline bounce? (try both, any differences, even subtle?)
Are you bouncing the exact same outputs you are monitoring while mixing? (easy to not do say if you are monitoring on headphone sends).
Is this static equally loud/constant though the whole time? Or does it come in bursts or is somehow modulated?
Some demo or not correctly licensed plugins will inject static noise often in short bursts.
Regardless, in a copy/tests session (do a Save Session Copy In) simplify the test session, remove tracks/sends etc. seeing if you can get the bounce to works OK.
Old 11-17-2023, 11:53 AM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Hi Treblecorp,
I created case 04711512 and coordinated this as well with our tech support team.
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
Old 11-17-2023, 01:02 PM
If song A has static, and song B does not, what plugins are used in A that are not in B? Some plugins make static or noise when they lose authorization, or are running in Demo mode, so this is worth a look
Old 11-17-2023, 01:24 PM
I fixed it by deleted the track and creating a new one
static sound in playback xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-16-2011 08:13 PM
static sound problem Chris Beaver Eleven Rack 10 01-25-2011 10:27 AM
Need of help of Static Crackling Sound!! acuraboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2008 07:11 AM
constant NOISE sound and Static/Poping sound jaynyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2007 10:10 PM
Need help w/pop sound at end of song and static!! arcada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-03-2005 09:47 PM
