Old 06-18-2015, 02:59 PM
mattz63 mattz63 is offline
Default Bank/Patch Change Behavior
I’m moving from Guitar Rig Pro 5 to the 11R. I’m still using the Rig Kontrol 3 as a foot controller. I may be losing my mind here—but when I first hooked up my 11R, I swear I that Program Change messages from the RK3 would only change patches from within the selected bank on the 11R. So if I’m playing patch D1, Program change 4 went to D4, Program Change 3 went to D3, etc.
Now, it seems the 11R behaves differently—absolute Program Change numbers are all that matters. Program 1 is A1, but 5 is B1, 6 is B2, etc.
First question: am I crazy? Did it not happen like that at first? Could be true.
2nd question: Does anyone know how to achieve the first behavior (switch patches only within the currently selected bank)? I want to change banks myself, and then use the foot pedals to change within the bank. Otherwise I need 100 foot pedals to change to each patch. I do have Midi Translator Pro (highly recommended) so anything is possible.
Old 06-21-2015, 08:17 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Bank/Patch Change Behavior
I have no idea. I've never used that pedal. You'll need to look at what exactly the pedal is sending and compare that to the MIDI list for the Eleven Rack, its in the back of the manual or the end of the User Options on the rack itself.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-21-2015, 09:50 PM
therealmf therealmf is offline
I can hardly imagine the first scenario being realistic. The 11r listens to Midi Program Change Commands. These commands are "hardwired" to the respective presets, i.e. MIDI PC "00" initiates A1 on the 11r, "01" calls A2, "02" calls A3, "03" calls A4, "04" calls B1 etc.
There is no way to change that assignment within the 11r.
This means if you want to "stay" within a certain bank you would have to program your control pedal to send MIDI pc commands 00 through 03 ONLY - and on ALL buttons you hit. So if you have a pedal with 10 buttons you would have to tell it to send "00" on button 1, "01" on button 2, "02" on button 3, "03" on button 4, "00" on button 5, "01" on button 6 and so on. Or (might be more useful) not to send MIDI PC commands at all on buttons 5 and up, but use them for other stuff instead (MIDI CC to switch effect blocks on and off).
This process of assigning the buttons to send certain PC commands (and not just incremental increase) is called MIDI mapping.
I don't know your pedal, but I doubt it was MIDI-mapped in this way.
Old 06-22-2015, 06:55 AM
Thanks--but by this scenario, both button 1 (PC 01) and button 6 (also PC01) would select Patch A2. I do agree though that behavior A is unlikely to have occurred.
Oh, of this I am fully aware...I know way more about MIDI than I ever wanted to. I can program the pedal's output myself. I have CC messages on the bottom 4 pedal to control Live recording, and PC changes on the top 4.
Patch and Bank changes MaxVelazquez MIDI 5 01-21-2008 04:25 PM
Trying to do patch bank sysex transfers Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-30-2007 06:40 AM
Recording patch bank changes- Help! JHenderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2005 01:31 PM
phone patch that won't break the bank RobMacki Post - Surround - Video 9 01-14-2005 04:10 PM
MIDI Bank and Patch Listings in PTLE BumE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-02-2001 09:07 AM
