PT 10.3 & 11 Installing Plugins
Hello!!
I have just managed to re-install 10.3 after upgrading to 11. I am now having an issue trying to install VST & RTAS plugins for 10.3. I've got a feeling that it is installing or trying to install to the 11.0 folders rather than the 10.3 folders. Has anyone had this issue that can lend a hand? Cheers CraveMac |
Re: PT 10.3 & 11 Installing Plugins
What issues exactly are you having? Obviously VST plugins don't work in pro tools! Are you installing the latest version of both 10 and 11? Are plugins not showing up in pro tools, what's happening? What OS version are you on and what interface are you using? Chris
Sorry didn't mean VST. Getting confused between the formats!! Think I have solved the problem by manually moving the .dpm to the plugins folder. Cheers |
You also haven't said what version of OSX you are running but in Mountain Lion Apple hid the Library folder. You can unhide it by following the instructions here: http://reviews.cnet.com/8301-13727_7...my-library-go/ For a co-install of PT 10 and PT 11 you're going to need PT 10.3.6 or 10.3.7; lower versions won't work. Also as you should know RTAS plugins aren't used in PT11 and PT never has used vst plugins although they can be installed on a Mac. I'm writing all this based on the fact I had PT 10.3.7 installed before I installed PT 11.0.2 |
I can and have found the plugin folders, like I have done in the past to move plugins to the unused folder for later use. Thanks for the help though |
I only assumed you were on a Mac because you didn't give any info on your computer system and I figured from the screen name you were. Cool last name! Glad you figured it out.
Did you update to Mountain Lion from "Lion" ? How did you do it .. update or clean install? I,m running a Mac Mini server with Lion 10.7.5 (it has a recovery partition) I thought i could just update/install over Lion but i read this from Avid …..We highly recommend you avoid updating an existing OS install to 10.8….Mountain Lion http://avid.force.com/pkb/articles/h...to-Mac-OS-10-8 Does this still apply? cheers J |
I still haven't updated from lion as of yet, however I am waiting to go to mavericks if PT10 becomes compatible.
Ah.. i see.
Y,know i cant even buy Mountain lion now on the App store since Mavericks become available. Guess its on at the online store. |
Need Help installing plugins... | branagan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-28-2007 10:32 AM |
installing a set of plugins, how do I do that? | thinksamuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2007 06:59 AM |
installing plugins | aishabag23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2004 02:36 PM |
installing plugins? | romerom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-12-2004 01:07 PM |
help installing plugins on the 001/mac | t ho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2002 03:22 PM |
