pro tools midi editor cuts audio from superior drummer
So guys!i have pro tools le 8 and superior drummer 2.2.1 ,and the problem is that when i draw or audiotioning notes from midi editor the sound is getting cutted,the playback is fine but really its not helpful not to hear the whole cymbal or tom when i m drawing it!!i ve checked many things like using 3 proccessors instead 4 or setting different parametre on buffer size but nothing changed...
i have to mention that i use a 4core pc with 4 gig ram and windows xp 32 please help me..!!:) |
Re: pro tools midi editor cuts audio from superior drummer
I do most of my editing of midi right on the instrument track(the track with SD inserted) and I sometimes get the same thing. I think toontrack has a new update, but I don't think it will help. I just learned to live with it myself and usually just back up the cursor and play thru my edit to give a good listen. If you post a Sandra report as described in the "Help us help you" thread, maybe someone will spot a hardware issue to check.
could you guys try this, i'm curious............
try moving the midi note (in slip mode) that is cutting out to the right ever so slightly. a 2 to 5 samples is a good starting point.
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Dragging MIDI from Superior Drummer crashes PT | lennieh | Virtual Instruments | 4 | 01-03-2012 01:08 PM |
Midi from drums through command 8 then superior drummer | Raoul23 | The Drum Room | 3 | 09-29-2011 05:15 PM |
Midi tempo question (superior drummer) | patswope | Virtual Instruments | 3 | 02-07-2011 05:07 PM |
How do i use Superior Drummer without any midi devices ? | Rwilliams0190 | Virtual Instruments | 15 | 06-06-2010 01:19 PM |
Superior Drummer + Pro Tools | Mike1983 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-17-2009 04:56 PM |
