Old 05-07-2009, 01:24 AM
Guss Guss is offline
Default Sort of a problem...
Greetings!
While I was trying to consolidate some audio clips, I think I pushed a wrong key when I introduced the keyboard shorcut. The clip was consolidated, but it went from the "waveform" display to something similar to "blocks", without being selected that display/mode!
Now everytime I consolidate a clip, or apply any FX, EQ, etc., the same thing happens. I can still listen everything that is on the clip, but cannot longer see it displayed in its waveform.
I don't know if I accidentally activated another "display option" or something like that. Can somebody tell me what could have happened and what can I do to solve it?
Thank you so much!!
Old 05-07-2009, 06:09 AM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Default Re: Sort of a problem...
by the track name in the arrange window there are the view choices... if you select waveform while holding option all tracks should now be back on waveform display. but I think you know that already..
beyond that try the trouble shoointg steps... database and volume trashing, prefs trashing, repairing permissions, re start... worst case if none of that works try importing session data from a brand new session. . maybe something in thee original session was messed up.
Old 05-07-2009, 07:04 AM
Shawn Simpson Shawn Simpson is offline
I'm not sure what is causing it, but I've been getting quite a few calls about this myself. The simplest solution so far has been to just select the region and choose "recalculate waveform overview" from the region list menu. (Not the one in the menu bar, but the one over the top of the region list on the right side of the edit window)
Old 05-07-2009, 07:35 AM
daeron80 daeron80 is offline
Is this another PT8 bug? Maybe I'll just give the whole version amiss and hold out for 9.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Color Sort hiroism Tips & Tricks 0 03-14-2007 10:50 AM
OT (sort of) NNXT kit neeel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-21-2004 01:55 AM
S&M,,well sort of,, Homebelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2003 03:42 PM
what sort of set up needed chrisG27 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-06-2001 11:04 AM
what sort of FWB do I need Steve Rosenthal Storage Subsystems 1 08-11-1999 12:58 AM
