Direct I/O limitation
I still use Digital Performer with TDM hardware. Occasionally I like to use MAS with Direct i/o instead of DAE. Only problem is that when I use Direct I/O it only sees interfaces connected to the Mix Core card. And no interfaces that are hooked up to the farm. Is this a limitation of Direct I/O or Digital Performer?
Is this something Digi could fix? It makes direct i/o hardly useable. I would love to get official word from Digi on this. Thanks |
Re: Direct I/O limitation
-Unfortunately, this is a limitation of Direct I/O. Only the first interface is recognized.
-Although I'm not sure if it is even possible, I do not think Direct I/O will ever support multiple interfaces. Brent |
This is is not exactly correct -- only interfaces connected to the first card can be used.
For example, this means you can use 2 888's or a single 1622 -- they just have to be connected to the Core card. -- Joe Digidesign Engineering [This message has been edited by Joseph Saracino (edited March 02, 2001).] |
Thanks, that's too bad.
Would it be possible to hook up my A/B cable on the first card and use the Apogee AD-8000 on channel A and ADAT bridge (1-8) on channel B. Then use ADAT 9-16 on the mix farm? This way I could at least get 8 ADAT ins/outs and 8 analog ins when using direct i/o. This would pretty much solve my problems. I suppose I could just try it, but I figured I would ask. Thanks for your replies. [This message has been edited by shadowbox (edited March 02, 2001).] |
1st 32 i/o channel limitation? | vieris | Pro Tools 11 | 5 | 06-23-2013 11:09 AM |
Digibase bug or limitation? | JimLeb | Pro Tools TDM Systems (Mac) | 12 | 02-08-2010 07:14 PM |
Ram Limitation? | jc7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-20-2009 10:50 AM |
32 Track Limitation | protoolsjimmy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-07-2007 12:19 PM |
Ram limitation. HELP !! | Allan Speers | Digidesign Hardware & Software | 4 | 12-10-2002 01:43 PM |
