installing plugins?
how can i install plugins into pro tools LE ? will TDM plugins work with LE ? whats the dizzle, bizzle?
Re: installing plugins?
Don't know about the 2nd question, but the plug-ins should have installation instructions with them when you run them. They generally work all by themselves, though you may be prompted to pick a install location....
1- you install them like any software. They are only available in the insert drop down menu and audiosuite menu. You will not find them outside Protools
2-TDM plug-ins do NOT work in LE. LE uses RTAS or wrapped VSTs.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Pretty much all plugins designed to be used with PTLE will install into the correct folder, but if they don't, you'll have to move them over to it. Of course, I've totally forgotten what folder it is...
As for TDM, no, they will not work with PTLE. The TDM format works with a different version of PT, and with dedicated processing cards. You need RTAS or AS plugins, which are compatible with PTLE. VST plugins by themselves are not compatible, but there is a program (a wrapper) which allows you to use them...at least, that's my understanding...do a search in the DUC for vst wrapper.
XP2500+, a7v8x-x, 60/80G drives, pc2700 Micron, SIIG 3 port, win xp home, Radeon video, ADS/WD 120 FW drive, 002r PTLE 6.1.1 stable as can be. |
Not necessarily...my Waves Native Gold are direct x compatible as well, so they work in the Sonic Foundry environment. Of course, the key words there are Direct X. Otherwise, it's what he said
thanks for the quick response time you guys!
PT 10.3 & 11 Installing Plugins | CraveMac | macOS | 12 | 11-04-2013 09:31 AM |
Need Help installing plugins... | branagan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-28-2007 10:32 AM |
installing a set of plugins, how do I do that? | thinksamuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2007 06:59 AM |
installing plugins | aishabag23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2004 02:36 PM |
help installing plugins on the 001/mac | t ho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2002 03:22 PM |
