Old 09-03-2018, 11:55 AM
Benoni's Avatar
Benoni Benoni is offline
Arrow How to make Pro Tools tutorials for FREE - Record screen & ASIO audio
This question gets asked all the time, "how can I record Pro Tools audio with my screen capture program".
Well, ASIO is notoriously difficult to capture. There are many reasons for this, but do you really care? Probably not. The good news is, that with the correct software, it's actually very easy to do. Plus, you can do it for free.
You need 3 things to accomplish this.
1. A way to capture the screen
2. A way to record the audio (PT, mic, system etc...)
3. (optional) A way to edit the footage
Much of what I will mention is geared for Windows as OSX is different with the CoreAudio stream. But you can still use the free Screen capture program I will link below. Also, if you already have a screen capture program that you like, such as Camtasia, you should be able to use the audio drivers I will link below to directly capture ASIO audio in Camtasia. This is not the ONLY way to accomplish this, there are other methods, but these are the ones that work for me.
Capture Audio Separate from the Screen Capture
An easy method to do this is to run cables from your audio interface into another audio interface or recorder (like a Zoom H6) and record the audio from Pro Tools. Then combine the audio with the Screen Capture in a video editor, or even in Pro Tools. I like this method because its straight forward, but it does add the step of needing to combine the audio later. It's not difficult to do, but some people don't have another PC and interface to employ this method, no big deal, there are other ways.
Capture Audio and Screen Capture together
This method is great since you don't need to combine audio later, but the drawbacks are you are limited to the driver you can use. Also, MAKE SURE you are recording ASIO audio and Mic audio to different tracks! I will go into this in the following videos, but I want you to be aware of this now. It is not wrong to record everything to one stereo audio track, but it limits what you can do in post. For example, if your voice track is buried under what is playing in Pro Tools, you can't fix this if you only have one track of audio. The two drivers I recommend are Voicemeeter Banana or the FL Studio ASIO driver. There is no way to only download the FL Studio ASIO driver (that I know of), but you can get the trial of FL Studio for free and the driver is included.
If you are new, watch the ENTIRE "How to make Tutorials" video. It will answer every question you will have. It will even answer questions you didn't know you had.
Once you decide on the method you want to use to capture ASIO audio, come back and watch the other two videos.
EDIT THE FOOTAGE
Some people think this is optional. If you are perfect in your delivery, great. But, most people make mistakes. This is where editing comes in. We have all watched YouTube videos that go on waaaaaay to long because people make mistakes and don't edit them out. This is lazy, don't be lazy. If your screen capture program includes an editor, you can use that. If you already have an NLE, that's fine too. Otherwise, I'll link some good free video editors below.
VIDEOS
THE ULTIMATE TUTORIAL ABOUT HOW TO MAKE TUTORIALS - FOR FREE!
https://youtu.be/lJCWNxlhGiM
VOICEMEETER BANANA | RECORD ASIO AUDIO INTO OBS STUDIO
https://youtu.be/26JmHix0ESQ
THE EASY WAY TO RECORD ASIO AUDIO INTO OBS STUDIO + BEST OBS SETTINGS
https://youtu.be/v8yohGa83Fw
▶Screen Capture (free)
https://obsproject.com/
You also have the option of the Streamlabs version of OBS. It's very similar and I prefer it for Streaming, but (currently anyway) I prefer plain OBS Studio for recording. Just be aware that you have a couple options. Please start with OBS Studio. Once you understand it, try out Streamlabs OBS (SLOBS)
▶ASIO Audio Drivers (free)
https://www.vb-audio.com/Voicemeeter/banana.htm
https://www.image-line.com/downloads...odownload.html
▶VIDEO EDITORS (free)
https://fxhome.com/express
https://www.blackmagicdesign.com/pro...avinciresolve/
https://www.avid.com/media-composer-first
All of these links will be in the Description of the above videos. Also, in the videos I mention that you don't need 60fps tutorials. This is true, 30 fps is fine and many systems may not be able to record 60fps videos. However, feel free to try it out, just realize it may make your video file much larger, and no one really cares if your tutorial video is 30 or 60fps.
Enjoy.
[UPDATE] 2020
More videos about screen recording a DAW
How To Use Two Audio Interfaces To Record/Stream Your DAW w/ OBS or Streamlabs
https://youtu.be/by07jwd1KE8
PreSonus Universal Control Loopback - Record Computer/YouTube Audio Into Your DAW
https://youtu.be/Eq6Pjrd6vss
PreSonus Universal Control Loopback - Record DAW ASIO Audio into OBS/Streamlabs
https://youtu.be/B0wLEzyJf-U
Use Interface Inputs and Stream/Record ASIO DAW Audio Into OBS or Streamlabs
https://youtu.be/lmdEtLWEVq0
Record Computer/YouTube Audio into your DAW - Voicemeeter Banana
https://youtu.be/jp34hdSR0R8
Record Computer/YouTube Audio into your DAW - Voicemeeter Potato
https://youtu.be/H3BuqC3e1a8
The ULTIMATE Guide To Screencast Your DAW - Voicemeeter Potato & OBS/Streamlabs
https://youtu.be/Dr9kF9yRQ74
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-03-2018, 02:23 PM
amagras amagras is offline
Default Re: How to make Pro Tools tutorials for FREE - Record screen & ASIO audio
Perfect, now we can simply link people here.
amagrasmusic.com
Old 09-03-2018, 03:05 PM
Benoni's Avatar
Yeah, makes it easier for everyone 👍
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-27-2018, 07:54 PM
zedhed's Avatar
zedhed zedhed is offline
As always....helping folks out.
Great work thanks Benoni
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 09-30-2018, 12:07 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Make this a Stickie!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 09-30-2018, 12:14 PM
Benoni's Avatar
I don't have that power. But it will be on my website once I have time to write it up there.
edit: and done
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-30-2018, 06:15 PM
DonaldM's Avatar
And here we all thought you had absolute power...
Old 10-01-2018, 10:31 AM
Benoni's Avatar
Ha.
Mods could technically make stickies, but it's not our forum to decide. We must use our power for good!
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 03-25-2020, 08:19 PM
Guy McDude Guy McDude is offline
Thanks for the video!
Question regarding your recording audio separately to the Zoom recorder, and importing later.
How do you ensure sync between the OBS video screen capture, and the audio from your stand alone recorder?
thanks in advance,
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 03-25-2020, 11:49 PM
Top Jimmy's Avatar
I draw three circles with the mouse on the screen and give a count at the top of each circle. ie: circle-1 circle-2 circle-3. I do this at the beginning and end. In your editor, align the beginning and if the end has drifted, enable varispeed elastic time and slip the end into place.
James Cadwallader
Free pro tools HD video tutorials: Side chaining and keyboard shortcuts chavernac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-12-2011 01:47 AM
Who's using which screen/audio capture for recording tutorials and why DrFord Pro Tools TDM Systems (Mac) 14 12-04-2010 08:33 AM
Pro Tools 7.4 Elastic audio tutorials...? Jaimo63 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-16-2008 11:22 AM
How to make ASIO default for Audio Playback toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-22-2004 10:35 AM
Free Tutorials for Pro Tools LE? pborkstrom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-18-2003 07:09 AM
