Old 08-14-2011, 07:57 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Default Artist Control V1 Touch Screen
Hi, I had a good deal on an Artist Control V1, and it's working almost flawlessly. The only problem I have is with the precision of the touchscreen.
Sometimes I touch the arrows in track view and it selects a track instead. It seems to select it randomly on the bottom row. In track view it's not really worrying because the consequences are minimal. But in softkeys view, it's really a disaster. There is no way I can program a shortcut that is slightly "destructive" since there is a risk that the touch screen behaviour will make me lose data.
Anyway, I'm just saddened that I cannot use the softkeys on the touchscreen because of precision issues. There are plenty of physical softkeys on this unit and the transport to workaround this issue.
Nevertheless, can this also be fixed with a firmware update or a feature I'm not aware of?
Old 08-19-2011, 10:07 AM
noizgirl noizgirl is offline
Default Re: Artist Control V1 Touch Screen
donno if this helps but .... ive been using a Bamboo tablet with stylus for several yrs now to save myself from carpel tunnel and have found that using the stylus on the McControl v1 screen works really well.
just a thought...
Old 08-19-2011, 10:13 AM
DigiTechSupt's Avatar
Have you tried a screen calibration yet? The FAQ has instructions on how to do so.
Avid Audio Tech Support
Support FAQ
Old 08-19-2011, 01:52 PM
Thanks, it is much better now!
Thank you also noizgirl, but it seems the calibration of the screen did the trick.
MC Control touch screen misreads coords of press Pasz Artist Series 15 12-15-2013 08:07 AM
Artist control screen sensitivity garnoil Artist Series 0 02-05-2013 05:48 PM
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze anotherchrisperry Artist Series 12 05-04-2012 01:45 AM
Touch to select on MC mix, does control touch screen follow? Led Artist Series 0 03-24-2011 05:36 AM
Touch Screen Control Surface? joy4u Tips & Tricks 2 11-30-2001 01:30 AM
