Old 11-27-2013, 07:54 AM
Scott Fahy Scott Fahy is offline
Default Aux FX sends not storing in snapshots
Everything is scoped, the aux/fx is on on the recall, no recall safe checked but when we make a change to the aux send levels into the reverbs or delays they do not recall. Puzzling? Any thoughts on what we're missing
Thanks
Scott
Old 11-27-2013, 08:46 AM
Brent Lind Brent Lind is offline
Default Re: Aux FX sends not storing in snapshots
Is the relevant aux defined as an "aux fx" as opposed to "aux mon"? Check this in options, all auxes have to be defined as one type or the other, purely for the sake of snapshot flexibility.
Old 11-27-2013, 09:33 AM
They are defined as AUX FX. No monitor feeds from FOH.
Old 11-27-2013, 10:16 AM
Well, just to be sure let's run through the obvious stuff.
- "Aux FX" parameter is scoped in the relevant snapshots
- Relevant inputs and outputs are scoped within the snapshots
- Parameters are not recall safed on either the input or output side
- Auxes are defined as "aux fx"
- not forgetting to store changes and the snapshots are not locked
- not in preview mode:)
Nothing revolutionary here, but it is easy to miss something small, since there are about 8 places one can defeat automation.
Old 11-27-2013, 10:22 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Hi Scott,
Check that the CH SENDS is not recall safe for the auxes. This is found on the Recall Safe tab, under the outputs sub-tab.
To help narrow down, disable recall safe completely and see if the issue is solved. If so, then something is recall safe'd and it should be pretty simple to locate where. I suggest making a copy of the shot file first, and then working on this (with speakers turned off) until you find the cause.
Let us know what you find!
Sheldon
Old 11-27-2013, 01:31 PM
Think I need to have a chat with our FOH engineers, every box on the recall safe outputs for the AUX's was selected. Thanks Sheldon
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 12:10 PM
Snapshots for multiple bands with Snapshots? thirdrailrecording VENUE Live Sound Systems 5 03-24-2010 05:04 AM
Copying Sends Levels between sends Premo Pro Tools TDM Systems (Mac) 11 09-27-2008 10:03 AM
Storing Audio... olliegreen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-21-2008 03:54 PM
Where are you storing these? Bee-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2003 05:09 PM
