Eucontrol 3.3.2 OS X 10.11.2
I can't see the application, it doesn't work, there's no GUI... what the hell is going on?! Is it just me?
Re: Eucontrol 3.3.2 OS X 10.11.2
here it is working on 10.11.2 ... maybe need to re-install EuCon ...
I had it working on 10.11.1... but after I did the upgrade, GONE. |
I've reinstalled EuCon also by the way. Trashed its preferences etc.
it is working right now 3.3.2 - OS 10.11.2 yes PT 12.3.1
I don't understand why mine isn't working then ... I seriously cannot see the graphical user interface, and when i quit it sort of shows me a scrambled view of what the settings window would look like (more like a white rectangle, than anything else)
what computer / system info .. there might be something there ...
I'm using a macbook Pro mid 2010. Just been a couple of hours on the phone with support and they logged in remotely into my machine. They were puzzled too. Did various test and resintalations and restarts. nothing. Also, found out the problem being the same whether using wifi, ethernet, and manual or dhcp addresses. the only way i have this working is by using the avid transport unit ONLY powered up. either ONLY avid control, or Avid mix, freezes the app/window. Although the E spinning symbol DOES seem to connect by turning black. But there's no control.
Only when the avid transport is connected, then this works fine. Otherwise no. With either multiple units connected, NO. With single mix, or control, NO. Cant see GUI. |
John your screen grab is interesting. It shows MC Transport working fine. Same as mine then :)!! Do you have a mix or control unit working fine on your setup??
sorry to resurrect this, but just in case anyone has a similar issue? My gui is fine on 10.10.5 but it won't connect unless i create a new admin user. Something in my current user is causing the app not to boot properly, or crash, or not do what it has to do: it pinches the units. but leaves them displaying the LEDs black... noting is shown (usually they would say Finder, Pt 12 Mac, or something). But not in this case.
What does EuControl W/S do? | maunaloa | Avid S1, S3, Dock and Control App | 10 | 06-19-2019 06:35 AM |
Eucontrol & Cpu | jky | Artist Series | 2 | 10-30-2016 09:38 AM |
EuControl 3.3.1 | Cryos | Artist Series | 10 | 01-13-2016 01:58 AM |
Where to get Eucontrol 3.2.1? | dumbeat | Avid S1, S3, Dock and Control App | 5 | 04-12-2015 03:08 PM |
EuControl | Trazan | Artist Series | 3 | 12-13-2011 12:57 PM |
