Mixdown on Outboard Console - How Do You ROUTE?
I've been mixing to an outboard recorder (Masterlink) but I'd like to mix to PT from the outboard console. I'm sure there is a simple answer - So My PT tracks are routed out to the console. I tried patching the mix outs from the console into a couple of spare channels on the interface. Signal does show up there. But in PT, there is a feedback loop when I hit record on those tracks.
Fail. How is this normally done?
Steve Holt The Inner Music & Media Group Voice Actor Steve Holt! Holt Remembers - Meetings With The Remarkable Windows 7x64 SP1, AMD Quad Core A8-3870 APU 3GHz, 8GB RAM, Graphics AMD Radeon HD 6550D Pro Tools 10.3.2, RME Fireface UC, MOTU 24 I/O, BLA Micro Clock Mk2, Soundcraft Ghost, DA-88 (3) Digital 24 Track TC
Outboard: Neve, API , Manley, Phoenix Audio, Teletronix, Drawmer, Universal Audio, Alan Smart , DBX, T.C. Electronics |
Re: Mixdown on Outboard Console - How Do You ROUTE?
mute the track.
I do it all the time on an SSL Duality. |
If you're using the 24 I/O, I would appropriate 23-24 for the mix input and monitoring output. The sum from the console goes to 23-24 input and 23-24 output goes to the 2-track inputs on the console for monitoring. In Pro Tools, make sure the mix track is routed to 23-24.
What I did was get a 2x2 interface to another computer which is my 2 track machine.
So, outputs 1-24 from my interface to tape returns 1-24 of the console. \ Tape 1 out from the console to the mixdown machine. Since the 2d machine is only recording 2 tracks, it doesn't need near the horsepower of the multitrack (ProToools) machine. In fact it's an AMD Athlon x2 w/4 gig.
Larry Sheehan - San Gabriel Sound |
Since you're mixing on a console, the likelihood that PT is being taxed is low IMO. I can't see a need for a second DAW unless you're looking to capture your mix at a different sample rate.
I use Soundforge for the mixdown computer.
I'm an old geezer, and I tried eliminating the 2d workstation, but it got to be a pain switching from listening to the multitrack to listening to the 2mix. This way I just select Tape1 as my console source to listen to the 2mix and mix to hear the multitrack. Unless I missed something (I switched from Nuendo), I'd have to mute the multitrack tracks to listen to the 2mix. I'm not saying that my way is better, just easier for me.
what about the control room section in Nuendo .. ?can you use that to switch your monitoring ..
I don't use Nuendo anymore at all. I got pissed off during the initial 4.0 debacle, and stayed with 3.2 till last year. I guess it might have worked, but I never bothered to set the control room up due to all the confusion over routings when it first came out.
Additionally I know of at least one project I lost cause I couldn't check the PT requirement off. They wanted to track at my place and mix somewhere else.
Using Delta 1010 to run outboard gear for mixdown | Studio Rat | Pro Tools M-Powered (Mac) | 0 | 05-23-2006 06:37 PM |
Using outboard without a console...... | coosticks | Pro Tools TDM Systems (Mac) | 3 | 06-07-2004 02:34 PM |
How to route outboard gear w/ Mbox | daryl bowden | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-21-2002 11:58 PM |
Outboard gear on mixdown? | unclemurray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-16-2000 07:25 PM |
Running outboard reverbs 'live' on mixdown (aux in) then what? Print it at 'the end'? | Jules | Tips & Tricks | 1 | 02-19-2000 05:01 AM |
