Old 01-12-2003, 04:25 PM
P-Loc P-Loc is offline
Default Importing Audio From CD - Help....ASAP!
how would i do that...the exact steps ..
i read the manual and tried several times..but i just cant do it..
can someone please explain..
BTW - i have Digi 001 (if that matters)
P-Loc
Old 01-12-2003, 04:36 PM
shaggy shaggy is offline
Default Re: Importing Audio From CD - Help....ASAP!
Version 5.1?
44.1k session 16bit, or other?
"The original nipper" Throw me a bone (Telefunken DI is ok too)
Old 01-12-2003, 04:47 PM
Notefarm Notefarm is offline
1. Under Movie select import Audio from other movie.
2 Select the trac you wish to import.
3. Select Convert
4. Now selectdesk top in the menu at top of the windowand click save.
Wait while "importing movie" happens.
5. Then a new window opens up "select tracks to import"
6. Now you need to choose the destination folder that the track will reside. Select your session folder then the audio files folder for the session
7. Select choose and wait.
Onece the files are processed they will apear in the Audio bin at the right of the scree. probally labeled Track 1. Left and Right, Drag them into the edit widow, and have a drink on me
Peace
NoteFarm
What games shall we play today?
http://www.notefarm.net/
Old 01-12-2003, 04:48 PM
Originally posted by shaggy:
Version 5.1?
<font size="2" face="Verdana, Arial">44.1k session 24 bit...
P-Loc
Old 01-12-2003, 05:13 PM
5.0 was a little different.
But, with the above instructions, (later version) choose: option after you assigned the folder where you want the converted 'track 1' to go. Change the word length to 24 bit.
Important- 9.1 and higher has no 'CD AUDIO' player. But, the CD will play from the DVD player. Itune will play it also.
I have installed a system 9.04 CD Audio player to 9.1. Not sure yet if it's compatible w/ PTs. BUT, at least I was able to turn 'OFF' autoplay (on the CD Player)
That is a problem which might cause a crash, if PTs is open.\
Best of luck,
Old 01-12-2003, 05:39 PM
..the only caveat.. this function relies on QuickTime.. so you have to have a current version of QT if you find it doen't work on your system.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-12-2003, 05:59 PM
Kickin.da.speaker Kickin.da.speaker is offline
<font size="2" face="Verdana, Arial">I'm not sure what difference you're thinking about, but the import audio function is NOT a PTLE function, is it a Mac OS function that works with Quicktime.
If you use Logic Audio for example, you can call this exact same function. I still use PTLE 5.0 and it works as described.
David.
6am eternal
Old 01-12-2003, 06:05 PM
man - im still confused...
i been trying this **** for tooo long now..
P-Loc
Old 01-12-2003, 06:11 PM
what u mean changte the "word lenth" to 24-bit?
P-Loc
Old 01-12-2003, 06:18 PM
P-Loc,
To make it easier.. do you own Toast..? If so, search your drives for Toast Audio Extractor.. use that to extract the audio from the CD.. then in PT use Import Audio.
If your Pro Tools session that you're importing the CD audio into is 24 bits, then in the Import Audio dialog you'll have to convert the 16 bit CD files to 24 bits (it just pads the data).
Notefarm gave you step by step instructions.. what's not working for you?
Rail
Platinum Samples
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
PT9 Crashing when importing audio from an audio CD Here and Now Stonehenge84 Windows 8 12-20-2012 03:26 PM
Audio Track Prpblems Please Help ASAP on a deadline bryced87 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-16-2011 10:26 AM
Need Help ASAP: audio record volume problem djcream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-28-2008 11:50 AM
need help ASAP about importing a track and BPM ikon1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-10-2004 10:09 PM
