HELP! -OS 9.2.2 update, now PT won\'t load
I recently upgraded my MacOS from 9.0.4 to 9.2.2. Everything else is fine but now PT 5.1 LE won't load. When I try to open, it freezes 3/4 through the process, stopping at "Setting up MIDI and Signing into OMS". Should I upgrade PT to 5.1.1? I read the description of the PT upgrade and it says nothing about functionality patches. Do I need to (ouch) downgrade my Mac OS back to 9.1 or similar? Running on a B&W G3 with Audiomedia card. Thanks.
Re: HELP! -OS 9.2.2 update, now PT won\'t load
Hmm...did you upgrade sequentially from 9.0.4? you know...first to 9.1, then to 9.2?
I would definitely suggest you upgrade PT, but I think you problem is unrelated to that. It sounds to me as if you need to reconfigure OMS and perhaps do a clean install of PT. I upgraded from 9.0.4 to 9.2.2 and I've been running PT5.1 with no problems, so it CAN work....I have a G4 dual 450 w/ 1.25Gb of RAM. Good Luck!
The Burner |
i ever have PT freeze at MIDI & OMS before. And it turns out that my preferences for OMS were somehow corrupted. So all I did was go into OMS setup (from the OMS folder, in System Drive; since u can't get into PT) And then create a new set of OMS Studio setup. I am not in front of my MAC, so i am not sure the actual steps or the filenames, but basically, all I did was to reinitialise / setup my OMS studio setup "using autodetect", and I could launch Pro Tools again. Hope this helps you. Regards, [Charles]
:: TWO ROOMS pte ltd :: Audio Post Production :: for Film / TV / Radio / Internet / Multimedia :: www.tworooms.com |
IMO...B+W G-3 runs best on 9.1
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
Hello,
It could be your OMS setup or the OMS current state pref. I would try the following if a new studio setup does not resolve it. - Trash OMS Current State located in System Folder > OMS Folder > OMS Prefernces. -Launch OMS Setup from the Opcode > OMS Applications folder -go to the File Menu and choose New Studio Setup. -Make sure both the Modem and Printer Ports are unchecked for USB midi interfaces and hit search. -OMS should locate your midi interface, if installed -Hit “Ok” twice and then name the OMS setup. -quit OMS and try launching Pro Tools regards, mike |
Thanks a bunch, guys. :^) I trashed the OMS prefs and voila!, PT opened. Didn't even have to trash the PT pref's, just OMS and then do the quick OMS setup dialog. I successfully opened a previous PT file, and was able to start recording a new one, so I think I'm OK.
RomeB www.toobluemusic.com |
Win 7 won't load PT 8 or update 8.0.3 | ag_perth | Pro Tools M-Powered (Win) | 4 | 05-12-2010 03:06 PM |
8.0.3cs1 update...now PT won't load... | ronwasserman | Pro Tools TDM Systems (Mac) | 8 | 01-22-2010 10:14 AM |
Altiverb 5 won't load since 10.4.6 Update | Stuart P. | Pro Tools TDM Systems (Mac) | 4 | 04-21-2006 01:49 AM |
Reason Adapted 2.5 won't load after update OS/PT | DrumaDrumin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-05-2005 10:23 AM |
Slow Screen Update & Can't Load Session Templates | klaatu | Pro Tools TDM Systems (Mac) | 5 | 10-17-2000 11:40 PM |
