Old 01-07-2019, 10:50 AM
[email protected] thecherish@gmail.com is offline
Default issue with delay compensation protools 2018.10
hi i am using protools 2018.10, and i am adding a 'ModDelay 3' to my vocal track but then the vocal track goes out of sync with the instrumental track, isn't delay compensation supposed to compensate ? also please see the attached screenshot
Old 01-07-2019, 11:35 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: issue with delay compensation protools 2018.10
Hi friend ! Please dectivate the low latency monitoring option below the delay compensation setting and test again.
Avid Carbon Interface
Protools Ultimate
Old 01-07-2019, 09:52 PM
hi jeam thanks for reply!
i tried to untick the low latency monitoring during playback but that didnt make difference.
Cherish
Old 01-08-2019, 08:55 AM
What is the end goal here? If the plugin has no inherent latency(caused by processing), then there is no latency to compensate for(just as there is none with many native plugins like BF76 or EQ III). The Time Adjuster plugin will also report zero latency because the plugin assumes you want to make the track later(and compensation would simply undo the delay setting)
Old 01-08-2019, 09:05 AM
albee here i am repeating my initial question below, as it was not about latency.
"i am using protools 2018.10, and i am adding a 'ModDelay 3' to my vocal track but then the vocal track goes out of sync with the instrumental track, isn't delay compensation supposed to compensate ? also please see the attached screenshot"
thanks
Cherish
Old 01-08-2019, 10:21 AM
zion zion is offline
thanks
Cherish
It might be because the plugin in your picture is set to 100% wet and your not hearing the dry signal just the wet delayed signal. The plugin is on an audio track not an aux.
Old 01-08-2019, 11:05 AM
Bingo^^^. Move the MIX slider back to the left. Most of us will use reverb and delay plugins on an AUX track and feed with a send
Old 01-08-2019, 11:14 AM
jeam25's Avatar
Excellent observation !
Protools Ultimate
Old 01-08-2019, 09:45 PM
right now after applying the plugin i am moving the vocal track to the left with some trial error (rough work) to make it sync with the instrumental track.
may be i should try delay plugin on aux and feed with a send and see if that solves the issue.
Old 01-08-2019, 11:11 PM
to be very specific and avoid confusion
The issue i face is that, after applying the delay plugin my vocal track goes out of sync with my instrumental track .
So i am having to shift my vocals to the left by some rough amount (trial/error) to make it in rhythm with the instrumental track. ( note: in my previous attached pic i had removed the instrumental track)
PROTOOLS 2018.3 Bounce delay compensation ERROR with UAD v9.5.1 AUX insert modulo2008 Pro Tools 2018 7 05-30-2018 02:10 AM
PT HD10 Delay Compensation issue etiennecaylou Pro Tools TDM Systems (Mac) 2 08-04-2013 02:02 AM
Delay Compensation issue... Is it Waves? acacia Pro Tools TDM Systems (Mac) 7 03-18-2010 11:53 AM
Delay Compensation issue mon Tips & Tricks 1 06-21-2008 08:34 AM
QT movie and Delay Compensation issue - bug? WildHoney Pro Tools TDM Systems (Mac) 10 04-12-2005 09:43 PM
