Problem w/ analog outputs from c|24
Hi
I'm running PT HD3 on a Mac Pro through a c|24. I'm trying to set it up so I can use the other 6 outputs ( A 5-6 and 7-8 for example) to send out separate stereo cue mixes using aux sends. The problem I'm having is that I can only send audio through outputs 1-4, When I try to send something through A 5-8 I can see it on the meters of the 192 i/o but I'm getting no audio 5-8 from the "control room out" D-sub cable. I've made all the paths active in the i/o menu. Is there something I'm missing?. A setting inside PT perhaps or some configuration of the c|24? Also, are there any suggestions for the best way to configure talkback in this situation? Thanks in advance |
Re: Problem w/ analog outputs from c|24
Are you creating aux channels with appropriate busses for these channels. It sounds like you're getting signal to the 192 but it Pro Tools has no output set in the mix/edit window as busses, there's no place for it to go.
hey scott are you just using 5/6 7/8 if so why don't you go out the cue out of c/24 into your seperate HP amps you should still have the c/24 talk back
to those outputs I'am thinking
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O Isochrone clock |
Keeps is simple for my feeble brain, Thanks for the idea! |
scott I tried the 5/6 out a master bus i didn't get any metering at all
don't no whats up with that
using all analog outputs in low latency | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-20-2010 10:56 AM |
Best use of Apogee 200 Analog Outputs with an HD2/192 | Mt.Everest | Pro Tools TDM Systems (Mac) | 5 | 12-15-2009 07:13 PM |
more analog outputs | BaileyBass | Pro Tools TDM Systems (Mac) | 2 | 06-13-2007 05:45 PM |
Analog Outputs | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-03-2007 11:48 AM |
Is there a way to get 16 analog outputs? | Avi Bortnick | Pro Tools M-Powered (Mac) | 1 | 01-19-2007 11:25 AM |
