PT 7.4 Total Failure
After 2 weeks of using 7.4 without a single problem, I came in this morning to find it will no longer boot up. It doesn't even get to the first screen. The apple dialog box that says the program unexpectedly quit is all that I get.
Heres what I have tried, trashing prefs etc, removing all plugins except the mixers, I tried the pre binding script but it said that I didn't need it and finally a total uninstall then reinstall of PT 7.4. I am out of ideas.... has anybody out there got any?
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Re: PT 7.4 Total Failure
Reinstall your OS. If that doesn't fix it, then it's a hardware problem. Or, before you do a clean installation of Mac OS, you might try detaching all the hardware, except your digidesign cards and interfaces, and see if that helps. But I'd definitely start with reinstalling Mac OS - that can only help. Ofcourse, you must make sure you have everything backed up, and that you have all the drivers and all the software ready before starting.
Kids, don't try this on a Mac [img]/images/graemlins/grin.gif[/img] |
Have you tried DigiTest to see if the Digidesign hardware is functioning correctly?
You might have a system drive in early stages of failure. |
Did you do the Clean or Safe uninstall of PT....
Try the Clean Uninstall. Then restart. And then install PT again. Before and after installation- Open Disk Utility and "Repair Permissions" Hope it helps... Next time it would help a little so get your system info and CPU model in order to trouble shoot better.
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
Thanks for the replies, Keep em coming
We have 2 partitions on the system drive the other has 7.1 on it which works fine so I guess that counts out digi hardware as the problem. Yes I did a clean uninstall I am thinking that I will need to re install the Mac OS
This very likely could be a problem with an corrupted OS service preference in your current account.
Try creating a new account, sign in under it and then launch Pro Tools. If it works, you'll know the problem is with your current account. |
Not particular to 7.4, but before doing a clean install of the OS, try running Disk Warrior. It's worth the fifteen minutes. Might get you back and running, like it did me this weekend. And once you have everything running properly, clone that puppy! I also prefer not to partition. I have previous PTs all on spare drives.
Kevin
Pro Tools Ultimate 2023.12.1.138 | Mac Studio M1 Max (64 GB) | Ventura 13.6.3 | Clarett+ 2Pre Pro Tools HD 9.0.6 | HD6 PCIx | Mac Pro5,1 (mid 2010) Westmere 3.33 GHz Hexacore (32 GB) | Lion 10.7.5 | Magma PE6R4-I | 192 i/o | Pro Tools HD 9.0.6 | HD3 PCIe | MacPro5,1 (mid 2010) Westmere 3.33 GHz Hexacore (32 GB) | Lion 10.7.5 | Apogee Rosetta 200 | C|24 |
One other thing to try - download and install the latest PACE drivers from www.paceap.com.
Thank you everybody for your ideas.
I opened another user account and everything is fine. Looks like I'm going to have to reinstall the OS. I cant believe how slow 7.1 felt after only 2 weeks. Anyway thanks again for all your help.
MOTU BPM is a TOTAL NO GO for PT HD | 25ghosts | Pro Tools TDM Systems (Mac) | 122 | 03-24-2009 10:14 AM |
HELP! Total Newbie... :) | GoofyDawg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-11-2007 04:57 PM |
NOW I'M IN TOTAL HELL!!! PLEASE HELP!! | schizo | Pro Tools TDM Systems (Mac) | 16 | 05-09-2003 11:07 AM |
Sorry am total new in all this and need a little help please | socata | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-17-2002 05:47 PM |
Boot failure- Mac OS ROM checksum failure...SCSI | shaggy | Pro Tools TDM Systems (Mac) | 11 | 06-23-2000 03:30 PM |
