Old 12-11-2016, 07:29 PM
Ben Jenssen's Avatar
Default Re: Best way to convert Sound Designer II files to wav?
Originally Posted by Stephen Bond View Post
This whole situation is farcical! Digidesign advised us to record our sessions with SD2 files rather than choosing the WAV option and then they drop support after all these years Now we are left scrambling looking for workarounds and solutions
Avid should at least support the importing of old SD2 Sessions and upgrading to the new standard natively, even if they don't want to continue with the option of saving as SD2.
Stephen
Obviously!
+1
Old 12-11-2016, 09:48 PM
johnnyv johnnyv is offline
Hey all,
first off, thanks to everyone for the suggestions!
I'm on a Mac.
A friend of mine recorded a live show about ten years ago...most likely in PT7 or something. The audio files folder has the audio. Because it's a live show, I presume that all files start and end at the same times. So, it's just a matter of converting the SDII format files to AIFF or WAV...
Old 12-12-2016, 01:17 AM
Stig Eliassen's Avatar
Logic Pro X supports SD2.
Old 12-12-2016, 01:19 AM
Stephen Bond's Avatar
You couldn't make this stuff up!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 12-12-2016, 06:27 AM
noteon studio noteon studio is offline
Also you can just add .wav to end of your file.
-janne
Old 12-12-2016, 07:28 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
There used to be free conversion utilities back on the real mac system.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 12-13-2016, 01:45 AM
-janne
I promptly added the extension to some of the audio files from a 2005 Pro Tools Session but alas, it didn't work
That said, I could open the files in QuickTime. After it did its conversion I could actually hear them
Anyhow, let's hope Avid see the light and add compatibility with there own Sessions, especially considering Logic X does
Stephen
Old 12-13-2016, 01:59 AM
Hanswurstlsepp Hanswurstlsepp is offline
I'm using Logic Pro 9 or X for that.
Works perfect.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 12-14-2016, 08:46 AM
So, there's no more support for SDII files, but at least they're still providing the "AVID Time-Shift" plug-in as the default TC/E setting, possibly just about the very worst sounding time stretching plug-in of the last 15 years*. Yayyyy.(/sarcasm)
*Oh, I forgot about the original Avid TC/E plug-in, which is even worse. And still supported too.
Old 12-14-2016, 09:59 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Originally Posted by midnightrambler View Post
As an aside, this has got to be one of the worst things about making music in the 21st century. I know 'twas ever thus (the number of actually useable 2" tape machines are presumably decreasing by the year, for instance), but who really knows whether we'll be able to read any of our current state-of-the-art files in 20 years' time, when e.g. WAVS have been rendered obsolete by some other slightly different but superficially better format.
True, but some companies are making new cards for old machines. I just bought a new servo card for my MM-1100 2". http://www.rtzaudio.com/pages/MM1200.html
But the tape lasts a long time. I am transferring tape from the early 70s and it plays fine (some require baking).
Let's hope file formats come with conversion software.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Will Files - Re-Recording Mixer, Sound Supervisor and Sound Designer Tom Graham Avid Pro Mixing General Discussion 0 09-08-2014 01:16 PM
Sound Designer I files scullionj Post - Surround - Video 5 07-19-2014 05:53 PM
Sound Designer 2 files pminda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-20-2005 12:51 AM
Sound Designer 2 files Bob-sw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-13-2003 12:56 AM
Sound Designer II Files and the 001? Rutles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-05-2000 06:30 PM
