Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-06-2013, 11:11 AM
Slice of Pineapple Slice of Pineapple is offline
Default Pro Tools 7.3 won't let external drive become record drive
I recently bough a late 2012 model iMac running OSX 10.8.4 and i have an old copy of Pro Tools 7.3 from a good few years ago. I have an mBox 2 mini interface and a G-Drive 250gb external drive (usb 2.0). I can install Pro Tools no bother (although i did have to get new ilok authorisation software and new mbox drivers) but whenever i go to open a new session Pro Tools won't let me change any of my drives, including the internal 1 tb mac drive into record drives. They are all fixed as transfer drives.
I've tried reformatting my external drive to all available options(journalled, case sensitive and stuff like that) but to no avail. Is it as simple as my software isn't compatible with the new os on the iMac or is there something I'm missing.
Any help would be great.
Cheers
Old 09-06-2013, 11:35 AM
Craig F Craig F is offline
Default Re: Pro Tools 7.3 won't let external drive become record drive
if you use Get Info on the external drives (command+i) what are the drives permissions and do you have Ignore Permission checked?
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-06-2013, 12:31 PM
browniespeaks browniespeaks is offline
are you on a mac? is the drive formatted NTFS (drive will be read only)? are you on a windows machine? how is the drive formatted? (drive attributes determine write-ability)
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 09-06-2013, 12:58 PM
As pointed out, trying to write to NTFS volumes is a common mistake, so check that. It should be HFS+ (aka Mac OS Extended (Journaled)).
I'd be pretty surprised if 7.3 actually installs and runs OK on Mountain Lion.
Will it record to your boot/system drive - just as a test try it. If not you might want to give up now.
The last OS X version to officially support Pro Tools 7.2 was Tiger (10.3). Official support is not he same as "will run", but you really are stretching it here.
Old 09-08-2013, 05:34 PM
Craig the drive is set to read and write. and ignore permissions is checked
Old 09-08-2013, 05:54 PM
Yes but what exact filesystem is on the drive?
Will Pro Tools record to your boot/system drive - just as a test try it. If not you might want to give up now.
Old 09-08-2013, 07:18 PM
sunburst79 sunburst79 is offline
I remember some issues like this cropping up back in the 7.3-7.4 days that only seemed to be resolved by formatting the drive.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Which External Hard Drive to Record with Pro Tools (Lacie, G-tech, OWC?) swingmanu Storage Subsystems 17 03-27-2015 01:52 PM
Pro Tools wont let me record to my external drive drewskers Pro Tools M-Powered (Win) 1 09-13-2010 01:26 PM
Record/Playback on an external drive vinyldj69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2008 07:51 AM
External Drive won't record... sheeptuf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-06-2008 04:58 PM
Record to internal or external drive? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-28-2005 01:19 AM
