Old 04-09-2000, 09:33 AM
KennyB KennyB is offline
Default simultaneous optical & spdif inputs
I am using my old ADAT as inputs to the D001, does this mean I can't use the spdif input at the same time (for a hardware reverb for example)? Which clock would you set as the master.
Any suggestions/insight....
Old 04-09-2000, 08:48 PM
Jeff D. Jeff D. is offline
Default Re: simultaneous optical & spdif inputs
Kenny,
You can use both the ADAT optical and spdif inputs at the same time. Only one device can be the master clock, though. Black face ADATs can't sync to external clock and must be the master when using their analog inputs. They also default to 48khz. I don't know about XT's
So, Digi001 and your spdif device must have their clocks set to "external".
Good luck,
Jeff D.
[This message has been edited by Jeff D. (edited April 09, 2000).]
www.jephthastudios.com
Old 04-12-2000, 10:16 PM
shaggy shaggy is offline
To use ADAT lightpipe you must set PTs to optical sync. Otherwise you will get timing spikes in with your adat converted audio tracks.
"The original nipper" Throw me a bone (Telefunken DI is ok too)
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? cueball73 macOS 0 05-22-2012 12:41 PM
Use Mac's optical SPDIF IN as 2 extra inputs? Alwyn Walker Pro Tools TDM Systems (Mac) 1 06-08-2007 01:05 PM
003 ADAT Optical & SPDIF inputs - simultaneous recording? ciacco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 03-28-2007 07:49 PM
simultaneous spdif optical rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-28-2003 02:25 PM
whats the difference between adat optical and spdif optical? Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-07-2002 07:42 PM
