DAE error -7100
I'm having crashes and getting this error:
DAE error -7100 It typically happens when I'm opening a session. If the session opens I'll hit play have no metering then the error comes up. After quitting out of PT when I relaunch the hardware initialize hangs and then the whole CPU crashes. PT8.03 Intel MacPro OS 10.5.8 2.8 gHz Zeon Quad Core 6 gigs ram Rockstor Firewire 800 in external chassis Video playback - QT out second port on graphics card ICON D Command |
Re: DAE error -7100
Is it a new system or this bug suddenly start happen?
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
Re: DAE error -7100
New problem on a system that ran stable for a few months at least.
Re: DAE error -7100
when things like that happen, it is very hard to find a diagnostic. Did you do the usual stuff like, trashing prefs, re-install PT and etc, etc...? Try to disconnect firewire devices. Maybe hard disk is failling. Run Digi Test. Open activity monitor (Application-Utilities) and start PT.
i found this on google: DAE error -7100. This error is reported by DAE and the TDM Plug-In when the application is trying to make a connection to a TDM port that is still connected. This particular error code is not an indication of a hardware problem unless it is preceded by another error message. A cold boot of the Mac should reset the TDM bus. but it's about PT LE http://www.digidesign.com.br/index.c...&nStartAt=1901 http://www.digidesign.com/index.cfm?...&categoryid=34
Error 7100 and Error 4, tracks have no voices help | WannabeSQ | Pro Tools TDM Systems (Mac) | 1 | 08-10-2006 02:24 AM |
error#4 and error #7100, pro tools crash! | audioluche | Pro Tools TDM Systems (Mac) | 2 | 06-19-2006 06:10 AM |
DAE Error #-4 and -7100 | araudio | Pro Tools TDM Systems (Mac) | 4 | 12-29-2004 06:57 PM |
PT6 error 7100 | AINSLIE | Pro Tools TDM Systems (Mac) | 8 | 03-19-2003 01:27 PM |
error 7100 | mario vejar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-28-2002 08:43 AM |
