Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 12-02-2018, 01:26 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Licensing and setting up a second system
I have a question in relation to licensing....
I have the 10/11/12 bundle with a perpetual license.....
I want to set up a second system to either run 10 or 11 my question relates to the licenses I have....
Does the perpetual license that came with the package bound to all versions of the bundle? it was my belief this perpetual license thing came out with ver 12 and 10/11 are not bound by this license.... correct me if I'm wrong which I'm sure you will.
I am intending to buy another iLok dongle to place either the 10 or 11 lic on do I need the perpetual lic to be on the dongle too? for these to run or am I forced to buy another perpetual lic?
I did have an old hackntosh that I could have tested this on but that died.
thanks in advance
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 12-02-2018, 01:48 PM
BScout BScout is offline
Default Re: Licensing and setting up a second system
They are a license collection that are locked together and cannot be separated.
You paid for one license and only get one license -- just this license lets you run older versions also.
If you want to set up a second system, you'll need to buy another license. If you aren't using them at the same time, you can also just move your ilok key between systems to the one you are currently using.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 12-02-2018, 02:04 PM
xrekcor's Avatar
thanks for your reply....
99% of the time I will just be able to move the dongle to the other system, but there may be times where it will be handy being able to run both.
So I guess what you are saying buying another perpetual lic by itself won't cut it I would need to buy another ver of 2018.* along with a perpetual lic, the latter so I don't get a renew every 12 months.
aaaaaaargh software made easy amazing what technology can do eh' haha
Rob
Old 12-03-2018, 04:24 PM
jeffro's Avatar
jeffro jeffro is offline
Depending on your needs you might consider a monthly subscription for the second system. That would help if you are working on a short term project and need multiple systems running simultaneously.
• linkedin •
Licensing system maintenance 8-9am ET on 11/22/2015 DigiTechSupt Technical Alerts 1 11-22-2015 12:05 PM
Setting up system ARoll10 Getting Started 3 01-19-2015 01:54 PM
Need help with setting up the system Stefin Getting Started 6 04-29-2014 12:16 AM
Setting up 5.1 system sysyphus300021 Post - Surround - Video 3 03-11-2009 08:43 AM
Please,help setting up system!!! Alejandro Pro Tools TDM Systems (Mac) 1 09-11-2002 09:50 PM
