Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 09-18-2013, 09:57 PM
jonz44 jonz44 is offline
Default Re: Mbox Pro hissing, crackling, master volume issues
I have checked the grounding. Still the same issue. As stand alone (when DAW / PC not running) it does not produce any hiss & crackling.
Jonz | Al Shams TV Production LLC
Mbox 3 Pro | Pro Tools 10.3.7 | Novation Impulse 25 | Novation ZeRO SL MKii | Mackie VLZ3 | Yamaha MSP 5 | Rode NT1a | Shure SM58
Intel i7 Quad Core, 8 GB RAM, 128 GB SSD sys drive, 1 TB HDD, Nvidia Quadro 600
Old 09-19-2013, 07:40 PM
I tried few things to see where the problem is coming from.
When the firewire cable is removed, the output is absolutely quiet even. The sound starts when I switch on the PC (with FW connected), but much less. When I start pro tools it increases, many variations of swish and small crackle sound while loading PT. Once PT is loaded it is sort of constant.
All this is happening with the main volume knob turned down fully. Also, I tied changing the FW cable. But same effect.
I also did a latency check with DPC latency check and it is showing good results, I feel. All green and average latency is showing 65ms.
I have done all W7 optimization recommended in Aivd website. I am at a loss where to look now.
It is really annoying Avid is not addressing this issue effectively. They should open their software to be used with other better interfaces if they can't fix the issue. Firewire interface is supposed to be good and may be better. But firewire cards in PCs are becoming increasingly up popular and difficult to get. I had to change my initial card avid recommended card which was not available locally (Dubai) and I had to buy it from the manufacturer.
Old 09-19-2013, 08:42 PM
Southsidemusic's Avatar
Originally Posted by jonz44 View Post
..... They should open their software to be used with other better interfaces if they can't fix the issue
What do you mean by that statement? Avid "opened" up their software for use of any 3rd party Hardware starting on PT9 and 10 and 11 are fully open to 3rd party interfaces and you don't have to use Avid HW anymore!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-19-2013, 09:04 PM
Thanks Southsidemusic.
I obviously were not aware ... fairly new to PT.
Old 09-20-2013, 07:21 AM
I managed to do some more tests today...
Used another pair of monitors (low end... Samson media1). I could not hear any white noises. Where as my standard Yamaha MSP5 hooked to Mbox it is giving white noises (constant hiss, sounds when mouse is moving and software is loading).
I hooked another Berhinger monitor amp in between Yamaha MSP5 & Mbox Pro. A lot more disturbances... Berhinger amp takes only unbalanced connections. However, Berhinger amp without input from MB Pro is quiet.
This leads me to think that this could be an earthing issue.
Can I have some suggestion how to have correct earthing?
  #16
Old 09-24-2013, 02:41 AM
Thanks for the inputs on this issue so far.
I have done a lot of search and reading in several forums. I will keep on searching and doing some tests and if I get a solution I will share it immediately. However, what I understood from experience of several people is that
  • This can happen due to several reasons. It is easy to rectify if this is caused by OS / peripherals setup issue. The grey area is the PC + firewire +interface + amp + monitor combination.
  • Almost all experienced no problem when the interface is unhooked from PC
  • Some monitors are not giving absolutely any issues. But some are too sensitive.
  • Making an earth loop seems too complex for me and some are suggesting to open up Mbox pro which I do not wish to do.
As I though earlier, I do not think my Mbox has some issues. So the only option at present is to live with it and continue searching and testing.
  #17
Old 09-24-2013, 05:47 AM
JoelG's Avatar
JoelG JoelG is offline
Perhaps you can look into one of these: http://www.ebtechaudio.com/humxdes.html
Also, double check that the wiring in your house is correct.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #18
Old 09-24-2013, 06:22 AM
sunburst79 sunburst79 is offline
Out of curiosity are you using balanced connections between the MBox and the speakers? There have been a huge number of cases over the years where changing the cables from unbalanced to balanced quieted down noisy outputs.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #19
Old 09-29-2013, 02:31 AM
Thanks JoelG for suggesting Hum X. I will look around and see if I can get hold of one (or two) in Dubai. Do you suggest this for the monitors or Mbox?
sunburst79, I am using balanced XLR cables for all my audio connections.
MBox 3 Pro Master Volume anackman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 09-10-2012 02:56 PM
Crackling & Hissing in Pro tools 9.0.6 [email protected] Pro Tools 9 1 04-14-2012 10:33 AM
Hissing Crackling m_atrix13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-06-2010 08:08 AM
hissing/crackling noise dj nik bean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-18-2006 03:51 PM
Hissing Compressors on Master Fader rnt_u_listnng Pro Tools TDM Systems (Mac) 1 07-03-2003 05:32 PM
