Old 05-24-2005, 12:27 PM
Monching Monching is offline
Default M box not recognized !
I recently just purchased the M-box w/ the protools factory bundle (with reason adapted, ableton,etc).. My computer is a Dell Dimension 8400 w/ windows xp pro. when i install the protools software it goes smooth.. but when i try to open it, it tells me some message about noise reduction and something about iLok as well. then it also tells me that the mbox hardware is not connected but it is and gives me an ok button or cancel button to click on. i'm trying to register the software but it wont let me go any further.
This is what it says when i try to register the software:
This version of broadband noise reduction LE requires authorization to run, but no iLok can be found. please install the iLok for this software.
please help!
forgot to add that i'm a newbie to this stuff.. thanks for the help everyone
Mac OSX 10.6.8
Protools 9.0.6
Old 05-24-2005, 01:53 PM
Riad Riad is offline
Default Re: M box not recognized !
You should post this in the Pro Tools LE forum. Use the Jumpt to box at the bottom of the screen.
www.carvelstudios.com
Old 05-24-2005, 02:07 PM
mix109 mix109 is offline
Re the s/w issues you have,seems that u have istalled the DV Toolkit option as well,which includes
the DigiTranslator option,DINR,and VocAlign software packages
Re the HW issues,make sure if your chipset is Digi Conpatible,check the USB cable or if u r using a hub
Hope this will help
Old 05-24-2005, 05:53 PM
Hope this will help
thanks mix109.. i'll check the chipset.. im not using a hub or anything though.. but the back of my comp theres like 6 usb ports.. it shouldnt matter where its plugged into right?
Mac OSX 10.6.8
Protools 9.0.6
002 not recognized lpfan799 Pro Tools 10 8 10-26-2013 11:40 AM
USB mic not recognized epianoqueen macOS 15 05-30-2013 06:30 PM
003 now not recognized? dreamslide720 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-22-2011 05:31 PM
002 Not Recognized, please help noisebrigade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-24-2007 10:48 PM
002 Not recognized? Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-26-2006 08:28 PM
