Old 05-19-2014, 04:53 AM
xcx xcx is offline
Default direct out (post delay) recording question
Hi!
I'd like to know if it is possible to record out of the direct out to protools post input delay setting but pre eq/hpf/dyn/fader...
anybody knows, work arounds will be appreciated as well!
Thanks
Old 05-19-2014, 09:57 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: direct out (post delay) recording question
The input delay comes after the top of channel pickoff point, and before the insert return pickoff point, so this isn't directly possible. But here's one workaround...
Patch the same input to two channels. Match the input delays on both channels. EQ, compress, process one channel as you normally would - this is the "wet" channel. Leave the second channel untouched (expect for delay) and send the Insert Return pick off to Pro Tools.
Alternately, make note of the input delay values on the channels and use these values to shift the tracks in Pro Tools. Same effect.
Sheldon
Old 05-20-2014, 11:18 AM
xcx xcx is offline
thanks, i'll try both but i guess i will go for the "set the track delay in protools" way as this is totally reversible if something goes wrong.
thanks!
Old 06-03-2014, 07:10 PM
ivanbatata ivanbatata is offline
Default Re: recording question
Hi everybody.
by the way, I wonder if there is the option to recorder to equalize, in S3L
Thank you!
what are you post users doing about QT 2 sec delay issue? alw4416 Pro Tools TDM Systems (Mac) 3 04-20-2008 08:01 AM
Another delay compensation post (i'm sorry!) planetkeys Pro Tools TDM Systems (Mac) 2 03-14-2006 11:59 AM
direct recording , line 6 or direct box? dannypassenger General Discussion 3 01-12-2005 07:17 PM
plug delay in tv post player Pro Tools TDM Systems (Mac) 2 08-09-2003 07:48 AM
What's the best BASS direct box direct to PT recording dw Tips & Tricks 18 05-13-2000 08:08 PM
