Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 04-11-2019, 01:22 PM
karegranat karegranat is offline
Default Re: User defined insert slot for EQ/DYN only works on the DAW, not on surface?
Sorry, but I think we misunderstand each other.
Example:
On a single PT track I have an EQ plug in slot a, and another EQ plugin in slot d. With my preference setting, when pressing the EQ switch on the process module the plugin in slot d should open in the DAW (this works), and the same EQ plugin in slot d should be opened/expanded into the knob module on the corresponding strip (this does not work, opens EQ plug in slot a instead).
Hope this clarifies my problem.
Thanks, Javed.
Old 04-11-2019, 01:40 PM
EddieJones's Avatar
Crap..The reason I was confused is that I couldn't believe our QA...and no other customer noticed this for over a year! Ok..looking into it and hopeful get it into this upcoming release. I think if you cycle around it gets back in sync. Thanks
Old 04-11-2019, 01:49 PM
That would be great! Thanks again!:)
User-defined keyboard shortcuts wevets Windows 12 08-16-2018 06:41 PM
User defined layer on Profile.. Audioartist VENUE Live Sound Systems 0 06-04-2018 06:22 AM
Move/copy multiple plug-ins to other insert slot at once pericoloso Pro Tools 11 14 07-11-2014 08:48 AM
PT 8.0.3 Snow Cat - Pre Release | 1 Second Time Lag when clicking Insert Slot 25ghosts Pro Tools TDM Systems (Mac) 6 10-30-2009 01:34 PM
6.7cs7/OSX10.3.7No user defined Keyboard shortcuts hanz marathon Pro Tools TDM Systems (Mac) 7 01-23-2005 02:53 AM
