Old 07-06-2015, 05:45 PM
studiorecording studiorecording is offline
Default PT12 C24 input problem
The PT 12.1 version will arm input monitoring from the computer and light the C24, but the C24 won't arm and disarm the input.
Record and others work fine just not input monitoring from C24.
Old 07-07-2015, 06:14 AM
Raggi Raggi is offline
Default Re: PT12 C24 input problem
Hi.
I have the same "problem". I tried this questin in another thread: http://duc.avid.com/showthread.php?t=369410
but no answer.
Old 07-10-2015, 09:35 PM
Interesting thing in Pro Tools 12.1 the input arm from a C24 controller does not work.
But on Pro Tools 12.1 HD the input monitoring works fine from a C24 controller.
Old 09-16-2015, 10:38 AM
jlmac39 jlmac39 is offline
According to my Sales Engineer at Sweetwater the input monitor switch should work on the C-24 even with a non-HD system with PT 12? He got this info from the Avid Rep.
He told me to make sure I was running 12.2 and I had the latest drivers. I was trying to figure out what drivers he was talking about? The only drivers that come with the system were HD?
Old 09-17-2015, 05:27 PM
Talked to my Rep at Sweetwater who forwarded the problem to Avid, they are aware of the issue and it is on their list to fix.
Old 04-04-2016, 07:55 AM
Pedro perez Pedro perez is offline
I have Pro Tools 12.4 and the input monitoring switch works with KBD shotcut but not on C24.
Old 04-04-2016, 08:00 AM
JFreak's Avatar
JFreak JFreak is online now
Traditionally input monitoring has been HD-only feature. I only use HD software so I cannot test whether it should work non-HD or not. Point being, if you see green input monitoring buttons on your PT mixer (on screen) you should also be able to control it with the surface.
Janne
Old 06-14-2016, 02:06 PM
I'm sure it will be functional on your next paid upgrade :)
Input Monitor Status Indicator missing in PT12 faderdominator Pro Tools 12 20 06-30-2015 02:50 PM
Problem importing AAF in PT12 mcqueen Pro Tools 12 1 06-12-2015 03:54 PM
Give Us Input Monitoring On PT12 Native !!!!! BushmasterM4 Pro Tools 12 40 03-27-2015 12:11 PM
PT12 input monitor? tomorrowstk Pro Tools 12 7 03-25-2015 04:28 PM
MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?) haney411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2008 10:22 AM
