Old 06-12-2012, 08:35 AM
propower propower is offline
Default MacMini server to replace MacPro?
I am running a PT10HD software/MetricHalo ULN8 system on a 2009 2.93G MacPro Quad (12G ram). No issues with the tower but as time has moved on I am doing all smaller sessions (Singer songwriter / Jazz) and projects really never go above 40 tracks. Very light VI use.
Am seriously contemplating
2011 MacMini server quad i7
replace Hard drives with 2 SSD's - 128G for OS and 512G for samples and audio (Crucial M4's ~ $525) and 16G of Ram.
External TB dock if I need a third drive
I am a freak for minimal fan noise so I was thinking of putting the unit on edge, leaving the bottom cover off and having a Silenx 120mm Fan blowing in 100% of the time. A small iso box for a mini looks very doable as well.....
I know there are at least a few running a system like this. Any comments on how much load it can take from PT before fans start spinning up?? On my MacPro (which geek benches about the same) I rarely go above 20% CPU load.
Any other thoughts are welcome too..........
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT2018.x Orion Studio 2017, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 06-12-2012, 01:59 PM
anackman's Avatar
anackman anackman is offline
Default Re: MacMini server to replace MacPro?
was thinking about this very same thing. anyone already doing this out there?
can a mac mini handle everything? i've never been sure.
10.11 OSX El Capitan
PT 12.4
Mac Pro Quad Core (Studio) + Mac Mini (Home)
UAD Apollo Duo
UAD Satellite Quad
Old 06-12-2012, 02:04 PM
The new quad core i7 with dual hard drives should be a potent little package!
Old 06-14-2012, 09:13 AM
Any one else??
Old 06-14-2012, 10:25 AM
getz76 getz76 is offline
Originally Posted by propower View Post
Any one else??
I wouldn't mess with the stock fan. It works, and changing the airflow won't likely improve anything. Any chance you can put it in a machine room and run cables? If not, a modest isolation box might work, but those are hard to get right.
The only thing that stinks about the Mini server is the integrated graphics. Shouldn't be too much of a hassle with Pro Tools, though.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 06-14-2012, 12:48 PM
dougied dougied is offline
I fond it quite odd that the server has Integrated Graphics and the regular Mini has both Integrated and Radeon.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 06-14-2012, 02:29 PM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Server class machines are not generally used for their display, in fact many servers don't have a display; running "headless" ...
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 06-14-2012, 05:26 PM
Numi Numi is offline
This is going to be my next upgrade.. my Mac Mini has been rock solid. Pain in the arse to upgrade the HDD and RAM but not too bad really. If they update the server model again, I will most likely bite. They pack a lot a punch and are quiet all around.
Equipment:Mac Mini(Late 2012) and Mbox 3
Audio Drive:OWC TIChip924/FW800
Software:OSX 10.8.5, Pro Tools 11.0.2/10.3.7, Reaper 4 and WaveLab 7
~On The LeVeL~
What would you replace an old MacPro with these days? EricWillhelm macOS 49 07-09-2013 08:37 AM
PT LE 8 and MacMini Server w/Lion? NHH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-06-2012 08:13 AM
2011 MacMini Server is Compelling Barry Johns macOS 11 09-02-2011 11:18 AM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
Applecare has offered to replace my G5 dual 2.5 with MacPro Chris Pro Tools TDM Systems (Mac) 3 08-26-2007 08:27 AM
