Old 06-07-2005, 09:49 AM
DerekDigital DerekDigital is offline
Default Importing DVD Audio/Mpeg audio
Is there any way to import a section of audio directly from a DVD?
I have been having trouble importing MPeg audio, also... is there an easy way to do this?
Import Audio from current movie.. does the movie have to be playing in Quicktime?
I have to extract audio from several live performances..some mpeg, some dvd...
thanks,
Old 06-07-2005, 10:03 AM
Mark Wheaton Mark Wheaton is offline
Default Re: Importing DVD Audio/Mpeg audio
You need to convert the DVD from it's own format to readable formats. There are programs such as DVDxDV and Roxio Popcorn that do this but they can take a long time and they will not work on copy protected material. And, keep in mind that audio on DVD Video is likely compressed and uncompressing it to AIFF or WAV will permanently downgrade the quality. Best to get the files from the source before they were encoded for best quality. If in fact you are referring to DVD-Audio this might be harder. And there are no affordable MAc solutions to author let alone reverse engineer these (that I know of) The Minnetonka Mac DVD Audio product is very basic and does not support high resolution audio.
Old 06-07-2005, 12:03 PM
froyo froyo is offline
Hello. Try this. It creates QuickTime movies. That way you can import video and/or audio as a QuickTime into a Pro Tools session.
Cinematize
froyo
Old 06-07-2005, 06:16 PM
Sonny Keyes Sonny Keyes is offline
Unless you're desperately picky about the audio quality, then if you have lots of little snippets to pull from a DVD, here's something that works pretty well:
http://www.rogueamoeba.com/audiohijack/
You just set it to 'hijack' the audio from DVD Player, and you can hit the record button whenever necessary as you play the disk.
Sonny Keyes
Toronto
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Code Audio and Mpeg movie Dogcode Pro Tools M-Powered (Mac) 1 08-06-2008 01:36 PM
Mpeg movie and Core Audio Dogcode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-01-2008 10:38 AM
Extract audio from mpeg? michael c Post - Surround - Video 8 02-22-2005 08:05 AM
extracting audio from MPEG + Mixing Pierre Paname Digidesign Hardware & Software 4 05-15-2003 11:38 AM
Extracting audio from MPEG movies straps Pro Tools TDM Systems (Mac) 4 07-27-2001 10:22 AM
