Old 05-31-2001, 09:21 PM
blink blink is offline
Default Updated to 5.1...now firewire drive \"not valid audio drive\"\"
I have been using 5.0.1 on G4 dual 500 with LaCie 60GB firewire (7200rpm) without problem since January. I just installed my 5.1 update, and when I load a session, I am prompted to locate an audio file. I locate the file in my project directory and a error dialog pops up saying: " XXXXX.aif is not on a valid audio drive (See ProTools Read Me for drive requirements) this and other files which are not on a valid audio drive will be copied to a floder on your choosing. Do you want to continue."
What's up with that?
Old 06-03-2001, 07:48 AM
Default Re: Updated to 5.1...now firewire drive \"not valid audio drive\"\"
Has anyone else had this happen after updating to 5.1? Is this a setup problem, or has the program been changed to effectively disable "unsupported" hardware?
[This message has been edited by blink (edited June 03, 2001).]
Old 06-03-2001, 05:14 PM
gohn gohn is offline
Hey blink,
I have the exact same drive. I was allready using 5.1 when i got the drive. However i was experiancing alot of problems with this drive oustside of protools as well. I found the lacie firewire drives to be the problem. I searched out this application called "Heat utilities" It's a free download of their web site (http://www.macpitstop.com/product-heat.lasso )Anyways, I now use their drivers instead of the lacie firewire drivers. Since then i haven't had a problem useing the drive with protools or otherwise. Hope this helps.
Old 06-03-2001, 09:02 PM
Thanks for the tip. I downloaded/installed Heat Utilities, and that fixed my "invalid audio drive" problem. Unfortunately, I then started getting DAE -9060 errors on several projects. I ended up removing any third-party firewire drivers, and let the Apple drivers take over.....seems to be working fine now. Whew!
Old 06-06-2001, 11:14 AM
Doc Doc is offline
blink,
I'm not using a firewire drive but I used to be able to bounce to a hard disk in my PC via my network with 5.01.
Now i get the,"---not a valid audio drive" message which is a bit of a pain.
Hopefully Digi Tech Suppt is reading this and can offer us a suggestion.
Old 06-06-2001, 11:16 AM
Doc Doc is offline
Well, it seems we both posted our replies at the same time. Good to hear you have fixed your problem.
I still have the error though
Old 06-08-2001, 12:08 AM
Doc Doc is offline
Digi?
Any ideas as to how I can use network drives with 5.1?
Old 06-11-2001, 05:23 AM
Doc Doc is offline
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
I can't make my drive a valid audio drive. help! thej99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-07-2006 06:40 PM
External Firewire Drive is not a valid audio volum nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-29-2005 11:09 AM
External Firewire Drive is not a valid audio volum nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-29-2005 07:58 AM
Firewire drive not "valid audio drive" DaleC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-04-2005 02:04 PM
